Call me an idiot, I tried using the install.txt (which does seem to have far more detailed instructions than anything I can find in here, unless I'm missing something), and when I try to run 'npm' anything, I get an error that it doesn't exist. I also can't get the hsproxy service to start, error being 'The service did not return an error. This could be an internal Windows error' etc. Any advice? the interface looks very cool, it's just all blank
Windows Style Live-Tile UI for HomeSeer
This is a sticky topic.
Originally posted by unbwogable View PostCall me an idiot, I tried using the install.txt (which does seem to have far more detailed instructions than anything I can find in here, unless I'm missing something), and when I try to run 'npm' anything, I get an error that it doesn't exist. I also can't get the hsproxy service to start, error being 'The service did not return an error. This could be an internal Windows error' etc. Any advice? the interface looks very cool, it's just all blank
The proxy not starting is usually a sign of trying to run node from a command prompt and not having admin privileges or your firewall is blocking the ports.
Originally posted by wposner View PostIf you installed node correctly then NPM should work. NPM stands for "node package manager". Node would need to be successfully installed on your system with all its paths property configured for npm to work correctly.
Originally posted by unbwogable View PostI downloaded from http://nodejs.org and installed to the default directory, then downloaded and extracted NSSM. Am I supposed to install Node to a different directory? The instructions don't say anything about paths until after the step to run 'npm install'
Originally posted by unbwogable View PostOk. Long day yesterday, logic was on the back burner. Got npm to actually do it's thing, but I get the same error (tried reinstalling the HSProxyService, says it's already installed). Same issue, blank tiles on HSMetro
You can also check you have the correct refid for a given tile, and that your firewall/etc are stup, by entering the following into a browser on the machine you're running HSMetro interface on and checking you get data back from HS:
http://<HS IP Address>/JSON?request=getstatus&ref=<device refid>
Addition:
The proxy service (I believe) is only used for updating the tiles without the need for refreshing your browser. This is a separate issue we can look at once you have data populated into the tiles the first time you call up the page)
Originally posted by naellis View PostWhich browser are you using....the UI does not work on Windows Explorer or Edge......only Chrome and Safari are currently supported I believe.
I have been using Chrome now since then.
sweetHW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Every time I blink. There's something new on this board.
Great work.HSPro: 3.0.0.194
PL: Insteon PLM 3.0.5.20,Insteon Thermostat 3.0.1.1 , UltraM1G, RainRelay8, UltraECM3, UltraPioneerAVR3, BLBackup, weatherXML, Jon00 Network & PC Monitor
HW : Win 7 64bit, Intel i7-2600, 16 GB DDR3 Ram, 60 Plus Insteon Dual Band Devices, Rain8 Pro2, Elk M1 Gold, Brueltech GreenEye.
Originally posted by kriz83 View PostWhat steps need to be performed to get this running on Linux ?
Is this based on droptiles, or on another Windows Tile lib?
I'm really looking for an alternative, hstouch is just too much hassle.
To install on Linux you'd create the HSMetro folder wherever the HS html folder is located and put all the files there. You would not need NSSM since it's a windows app used to create a windows service, but you would need to install NodeJS. The installers for various OS types can be found here: https://nodejs.org/dist/v4.2.3/
Once you get node installed, you can then run the NPM command to install Faye to the HSMetro folder. You need Faye for the proxy. Once Faye is installed,I'd start with a terminal instance of the proxy to make sure everything is running correctly. Once you get active updates in the UI via the proxy, then you can look to create some sort of auto start linux instance of the proxy. I'm not a regular Linux user so I'd have to google around for exactly how to do that.
The configuration steps are the same on both Windows and Linux so make sure you edit the appropriate files and make the required changes.
Got it working now, thanks !
Really liking this !
Few questions/suggestions:
- How do you span a button over multiple columns ? (e.g. first row has 3 button, second only 1)
- On my S6, N5 and N7 I have to refresh the page after going back to the browser before it works
- I'm noticing a delay of 1-2 seconds after turning a lamp on in the UI, is this normal ?
- Maybe its a good idea to put this on github or something, so others can join in ?Last edited by kriz83; December 8, 2015, 02:56 AM.
Originally posted by sputnik View PostHey Wposner,
I've put together a style guide that you can use for reference if you want. It contains details about type, spacing, and other stuff that may be useful.
Link to style guide (download and view at 100%, dropbox's viewer doesn't always work well):
https://www.dropbox.com/s/7hztsr3rjf...guide.png?dl=0
Link to a zip that includes up, down, and humidity png icons:
https://www.dropbox.com/s/wenjkxf01c...icons.zip?dl=0
Attached is a preview of the finalized UI. Full view link (best at 100%):
https://www.dropbox.com/s/vbptzmafqzrhxng/ui.png?dl=0
If there's interest I can also make the icons that I've used in my mockups. Let me know.
