Yes the plugin supports warnings. It creates a device which uses the string to display the warning message and the value to determine if there is a warning.
You can monitor the value (0=no warning / 100 = warning) and take action on the device changing (email it / send message to XBMC etc) using a script.
I just posted a new version that supports the French atom feeds. Consider this beta...
The plugin has a "parse" configuration page which allows the user to pick a suitable image for the text received in the forecast. As this is not hard coded it can be used for both the English and French feeds.
