Is it possible to connect the PLM via a serial to IP converter over Ethernet, like a Global Cache IP2SL Ethernet to Serial Converter? It would add a lot of flexibility on where to install the PLM vs, where the controller is located. Also, RS-232 ports are more of less going away from today's SFF computers, like the Intel NUC.
Connect serial PLM over Ethernet
Originally posted by johan View PostIs it possible to connect the PLM via a serial to IP converter over Ethernet, like a Global Cache IP2SL Ethernet to Serial Converter? It would add a lot of flexibility on where to install the PLM vs, where the controller is located. Also, RS-232 ports are more of less going away from today's SFF computers, like the Intel NUC.
please report back your results.Mark
HS3 Pro 4.2.19.5
your device should have a driver that allows you do this? this is not a function of the plugin
the plugin doesn't need to know anything other than the com port you are communicating withMark
HS3 Pro 4.2.19.5
