Are there no free scripts/plugins available for the one-wire bus using a DS9097U other than Pete's?
Free one wire script/plugin available?
I think you went through this before when you were helping a friend. Since then I provided a free xap application for the DS9097U. I believe it is located on the wiki at xapautomation.org. You can also use the owapi object from DallasSemi's set of drivers and do it in a script. There were some examples posted in the past on this board using owapi.
Well a search for owapi didn't turn up any code examples.Last edited by Rupp; December 6, 2004, 02:20 PM.
patsikes
Check out DigiTemp
Hey Rupp,
I build my 1 wire interface many years ago and use a software called DigiTemp available at http://www.digitemp.com/software.shtml. It has worked very reliably.
I have a script on my web site that reads the sensors and does some SQL logging if you are interested.
