| General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer. |
September 15th, 2008, 12:37 AM
Script Error - Anyone know how to fix this?
<TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGDateTime1 noWrap align=left>9/14/2008 9:34:23 PM </TD><TD class=LOGType1 align=left colSpan=3>Error </TD><TD class=LOGEntry1 align=left colSpan=8>Running script, cannot add script engines: Unable to cast COM object of type 'MSScriptControl.ScriptControlClass' to interface type 'MSScriptControl.IScriptControl'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{0E59F1D3-1FBE-11D0-8FF2-00A0D10038BC}' failed due to the following error: Error loading type library/DLL. (Exception from HRESULT: 0x80029C4A (TYPE_E_CANTLOADLIBRARY)).</TD></TR></TBODY></TABLE>
September 15th, 2008, 05:11 AM
-Rupp
September 21st, 2008, 04:54 PM
Rupp,
THanks of the reply. I followed the link and the REG update was successful. But it appears to not have done anything. Error in HS Log appears very similar to above. Note that I did not boot; I'm recording the game right now :-)
October 7th, 2008, 11:03 AM
Can't seem to get rid of this error in the log. I tried the suggestion above, but it still shows a problem...
Functionally, HS seems to be ok, but i'm afraid it'll eventually affect something...
February 1st, 2009, 03:37 PM
I have this problem too, and it doesn't go away when I try the regsvr32 fix detailed in other columns. It appears to be preventing the following plugins from working - UltraM1G, UltraMon and Squeezebox.
Any advice on how to fix? Totally clean install of Vista - applied all service packs, and then installed HS PRO
Jon
February 5th, 2009, 10:43 AM
Jon
Try loading the script control using this link:
http://www.microsoft.com/downloads/d...displaylang=en
-Rupp
February 5th, 2009, 10:48 AM
Originally Posted by Rupp
Rupp,
Thanks for the advice - i've actually given up now and installed XP, and all is running fine. I think I will leave the modern stuff for when HS is Windows 7 compatible and upgrade next year.
Jon
February 5th, 2009, 10:54 AM
Rupp,
Jon
Good choice
-Rupp
February 9th, 2009, 11:39 AM
I am not so sure that loading XP was necessary. The issue was not that the script control was not loaded properly, but that something referencing the script control was not installed or set up properly. As one person mentioned, it was only affecting some plug-ins, not (apparently) HomeSeer.
I would like to know from the plug-in authors what they are doing, if anything, with scripting. If it was a HomeSeer installation/update issue, then we would like to fix it, and if it is something the plug-ins are doing wrong, we would like to help them get it fixed.
Unfortunately HomeSeer's VBScript support is dependent upon the MSScript control, but so far issues on Vista have always been fixed by registering the control. It is a very old system that has not been updated (and will never be again) since 2004.
If you are doing anything with scripts, especially if it is inside a plug-in, then they should start migrating over to VB.NET scripts as those will at least go a little longer before they get deprecated.
Rick Tinker (a.k.a. "Tink")
HomeSeer Technologies
February 9th, 2009, 11:46 AM
I might be wrong but I think the scripts that weren't working were ones that aren't .net yet? namely UltraMon, UltraM1G and Squeezebox. I did try several hours to get HS to work with scripts properly - found a few links that pointed me at CLI commands, but the problem remained. I didn't try Rupp's suggestion above however.
Jon
February 9th, 2009, 11:51 AM
I would definitely try it - that is a download and (probably) automatic install of MSScript.ocx. What the error is saying though is that a type library that uses it is having a problem, so it may not fix it.
The other method is that you probably already have msscript.ocx on your system from the HomeSeer installation, it is just not registered. Go to your \Windows\System32 directory with a command prompt and type:
regsvr32 msscript.ocx
If it comes back with a message that the registration succeeded, then try starting HomeSeer again and see if it works.
February 9th, 2009, 11:53 AM
Wish I could try it, but I've gone back to XP now :-(
I will consider giving it a go this weekend, but the general consensus here seems to be that HS runs best/easiest on XP.
Jon
February 9th, 2009, 11:58 AM
Oh yes - if you have made the switch to XP, STAY THERE.
There might come a day, Windows 7 is rumored to be it, when there is a fixed version of Vista. Until that day, people either go back to XP or move on and get an Apple!
Vista is the next generation of Windows/Me if you remember that poc.
February 10th, 2009, 07:42 AM
Rick,
I'm from the Mac world - 20 years hated Windows - I looked at HS as my main mac was in my study and I had just installed a Windows Home Server in the basement to pool my storage. I needed to get my home automation from my mac onto a PC (i.e. WHS). I googled and eventually found Homeseer and its pretty much consumed the last 8 weeks of my life and all my disposable income! However, it has opened my eyes to the Windows world - building PCs, the different OS's and I must say my Mac is hardly ever used now. I like the Mac, but the Mac world is a little boring - not a lot of solutions or choice - for example on my HS box I rely on Lantronix Port redirector and Stunnel to name a few third party solutions - such solutions do not exist or play nice on the mac. That being said, HS on the Mac would be a good development, but HS devised for the WHS might be a better place to spend your time.
I have Windows 7 running on my media center - it is my main TV - on all day, records non stop and plays lots of movies. IT NEVER CRASHES - my wife is very very happy with it and we can wave goodbye to 2 years of Vista Media Center and its perculiar behavior. I cannot wait for 7 to be released, and more so for HS to support 7 - then I can upgrade all my PCs to 7 and have done with the constant XP/Vista/2003/2008 decisions I seem to be facing these days. I also hear WHS is moving to a form of 7 next year. And it seems as snappy as XP.
Jon
February 10th, 2009, 08:22 AM
as one of the rare freaks who loves Vista, I guess all I can say is that I'll look forward to W7 even more! Tell me...does W7 MC support Vista extenders?
February 10th, 2009, 08:52 AM
Yes, not only does it support them it makes them better. 7 transcodes all media on the server and streams to the extenders on the fly, so they play anything that the server will play. Out of the box, 7 plays all my media apart from .mkv, but that is easily fixed. So now for the first time ever, I can play everything on my extenders.
Jon
February 10th, 2009, 09:13 AM
whoah!
Wait a sec...so for instance - my whole dvd collection that I have on my 2 TB raid 5 array...I use the mymovies media center plugin. So now I can watch those via an extender!?
(sorry to hijack the thread)
February 10th, 2009, 09:18 AM
Yes, you can actually now do this without the MyMovies plugin, the 'DVD Library' is now the 'Movies Library' and you can play VIDEO_TS on MC and on extenders
Jon
February 16th, 2009, 10:30 PM
I am experiencing this error too with setuphs2_3_0_19. I am using a ghosted install of Vista Home Premium SP1 and have *never* experienced this error when installing setuphs2_2_0_66.
I would assume HomeSeer tech would want to fix this error as it may turn away people trying out HomeSeer.
Ultrajones
February 16th, 2009, 10:34 PM
This suggestion did not work for me.
| Thread Tools |
| Display Modes |
Linear Mode
