Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion
Lighting & Primary Technology Discussion Lighting & Primary Technology General Discussion
Old September 8th, 2009, 03:17 PM
floydenheimer
Guest
Posts: n/a
Z-Wave dimmers and LEDs
I have 4 Cree LR6 downlights on a switch that I would like to change to an RF dimmer. Does anyone know if which dimmer would work best for this setup? Cree has a list of recommended dimmers here but none of them are Z-Wave.
http://www.creelighting.com/download...%20Dimmers.pdf
Thanks in advance!
Old September 8th, 2009, 07:35 PM
dschoppe dschoppe is online now
I'm not using Z-wave dimmers with the LR6s yet, but I have a house full of LR6s (~60) running on Lightolier Compose dimmers (X10 variant) without issues. The lights dim to about 20% before turning off. The Compose dimmers are all 3-wire (requiring a neutral) and they are rated for incandescent and magnetic low voltage transformers. If I were going to try Z-wave with the LR6, I think I would stick with a 3-wire dimmer such as this Leviton:
http://www.leviton.com/OA_HTML/ibeCC...&section=15186
I haven't actually tested this combination though so if you buy one, make sure your retailer will take it back in case it doesn't work as expected. Please do post your findings if/when you locate a Z-wave dimmer that works well with the LR6s.
Don
Untitled Document
NEW!
New Products
