This is a simple plugin I wrote that listens on a TCP port for incoming strings and triggers events when matching strings are received. I use it primarily with iRule (http://www.iruleathome.com) but I'm sure there are many other uses.
By default it listens on port 6969 but you can change this by editing HSPI_HSDRTCPTRIG.ini in your HomeSeer\Config directory.
Once installed and enabled, a new trigger type is added: "Received TCP String".
Received strings are case sensitive.
Hope you find this useful
-David
-David
