Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Software (Older Versions) > HS2 / HSPRO
HS2 / HSPRO General discussion about HomeSeer HS2 and HSPRO
Old November 16th, 2011, 03:18 PM
kbrady kbrady is offline
Seer Plus
Syntax-location for local HTML files
I want to double check how and where to place HTML files and their associated images to make them available to HSTouch designer where I can have them appear in screens . Within this screen. I would create. I believe a text box? I have "is HTML" set to true
---What I thought I should do was to place these in - Program Files x86\HomeSeer HS2\HTML\Kevin HTML\Temp+Settings.HTML.---what I put in the text box is--
http://10.0.0.50:81/Kevin/Temp+Settings.HTML
The content of this. Is----:<html><body>
<img src="Temp+Settings.PNG">
</body></html>----
I keep the Temp+Settings.png. In the same directory. I do not define a\images\directory---
If I open the HTMLfile by launching it in a browser it displays correctly. However, if I try to launch it from a text box within HSTouch I get a 404 error. I have this URL in the text box
----this is the error from the HomeSeer log----." 11/16/2011 12:52:40 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files (x86)\HomeSeer HS2\html/Kevin/Temp Settings.HTML"
I know I am asking about something basic. Thank you in advance. Any tips appreciated. Kevin
Old November 16th, 2011, 03:26 PM
AutomatingIT AutomatingIT is offline
For one you are missing the HTML where you have Kevin ie Kevin HTML
Old November 16th, 2011, 06:07 PM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
Try: http://10.0.0.50:81/HTML/Kevin/Temp+Settings.HTML
HS3 Pro Edition 3.0.0.258 / HSPro 2.5.0.80
HW: Stargate | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net | RFXCOM | QSE100D | Vantage Pro | ECM1240 | X10:
Compose, XTB-232, -IIR | Edgeport/8 | Way2Call
Untitled Document
NEW!
New Products
