Go Back   HomeSeer Message Board > Audio & Video Support > Camera Plug-ins > NetCam
NetCam The NetCam plugin provides access to network based cameras.
Old July 5th, 2012, 04:02 PM
sweden's Avatar
sweden sweden is offline
Default Presets for Axis PTZ 213 to use in HSTouch
Im using a Axis PTZ 213, i have programed some presets in the camera and it work great IE, safari, application"AxisCam" in iPone and iPad.
How do i get this presets awilable in HSTouch?
I read the tread
http://board.homeseer.com/showthread...ferrerid=65945
And i liked it alot, but its not for for the Axis PTZ
I would also use the microfone and speaker fuktion and the I/O ports(im having the 213CM)
And changing the videosurce from YC to BNC from a buttom in the picture whitout needing to go to the settings
Old July 5th, 2012, 05:22 PM
huggy_d1's Avatar
huggy_d1 huggy_d1 is offline
Default
I read the tread
The way I did presets was to create events that trigger the url to set and goto the various presets I want to use. In my case, that was 'home' or default position (which was not the same as the power-on home position of the camera), and 2 other preset positions.
Once I had events, I triggered buttons to set and goto the presets by running the correct HS event.
I also added motion controls for pan & tilt so I could set them from HSTouch as well. If your camera has url for pan/tilt commands, create events for those and call them with the right directional arrow button.
I created a 'setup' screen that has 'set' and 'test' buttons and arrows and shows the camera image. It works very well and because I used events, I copied the events and screens and made 3 sets of screens and events for 3 cameras and quickly had them all working.
huggy_d1
Automating made easy
Old July 6th, 2012, 01:11 PM
sweden's Avatar
Default
Ok
But i don't know the URLs to move the Axis 213PTZ camera.
Were do i find the url's?
Old July 6th, 2012, 06:11 PM
huggy_d1's Avatar
Default
Ok
A quick google search of your question came up with a link that might work:
http://www.networkcamerareviews.com/...about1653.html
huggy_d1
Old July 7th, 2012, 07:03 AM
sweden's Avatar
Default
I found the right url
[url]http://user:pass@192.168.0.193:1417/axis-cgi/com/ptz.cgi?gotoserverpresetno=1
[url]http://user:pass@192.168.0.193:1417/axis-cgi/com/ptz.cgi?gotoserverpresetno=2
But in what action you apply the url
I tryed to do this event but no luck
Axis 213 PTZ Preset 1 Door - Manual Only -
Launch Application: [url]http://user:pass@192.168.0.193:1417/axis-cgi/com/ptz.cgi?gotoserverpresetno=1
Old July 7th, 2012, 07:06 AM
huggy_d1's Avatar
Default
I found the right url for preset the camera
http://user:pass@My_IP/axis-cgi/com/...rverpresetno=1
http://user:pass@My_IP/axis-cgi/com/...rverpresetno=2
Launch Application:http://xxxx:xxxx@192.168.0.193:xxxx/...rverpresetno=1
Try using the hs.geturl command. That's the command most of us seem to use.
huggy_d1
Old July 7th, 2012, 07:45 AM
sweden's Avatar
Default
Thanks for your qvick answers.
Works great whith the
http://192.168.0.193:1417/axis-cgi/com/ptz.cgi?gotoserverpresetname=Door
And using the preset names from the camera
And not using the username and password......
Tags
213cm, 213ptz, axis, ptz camera, ptz preset
Copyright 1998-2011 HomeSeer Technologies, LLC
