HSTouch for Android release notes for released versions.
The release notes for any Beta versions is here:
https://forums.homeseer.com/showthread.php?t=184028
The latest releases are available in the Google and Amazon App Stores and the APK is posted at the end of this post.
Changes in 1.0.0.163 (Release):
* Removed "Powered by World Wide Weather" text from weather screen as weather is no longer provided by that service
Changes in 1.0.0.160 (Release):
* Fixed passcode being presented when screen was not passcode protected
* Fixed passcode timeout setting not being honored
* Images are cached per page to reduce memory use and speed up page draws
* Fixed sliders not working in some projects
* Fixed sliders not handling negative values
* Fixed time not updating with custom projects
* Fixed passcode screen not appearing
Changes in 1.0.0.141 (Release):
* Fixed issues reconnecting
* Threaded the camera views to prevent UI lockups
Changes in 1.0.0.139 (Release):
* Fixed water valves not being controlled
* Minor fix for re-connection to server
Changes in 1.0.0.136 (BETA):
* Fixes for media plugins
Download:
https://homeseer.com/updates3/hstouc...se_1.0.136.apk
Changes in 1.0.0.134:
* Fixed elements not updating if associated device contained a value formatted as "34,56"
* Fixed action to simulate a release on another element
Changes in 1.0.0.133:
* Fixed Toggle action not working
Changes in 1.0.0.132:
* Fixed drop lists not associating with devices
* speed ups for displaying video
* Energy info is only updated if it is actually being displayed (speeds up display)
* Increated communication buffers for faster communications
* Fixed screen flashing when "return to main screen" option is enabled
APK is here:
https://homeseer.com/updates3/hstouc...se_1.0.160.apk
Download:
APK is here:
