*** BL Plugin Debug Logging ***
    ** This is very important to do - only needs to be done once
    All of my plugins will be updated over the next week
    Once you update one of the plugins and enable debug logging in the plugin, it will create a BLDebug.ini file in your config folder
    Here are the contents of this file:
    [Settings]
    debugLogMaxSizeLinuxMB=500
    debugLogMaxSizeWindowsMB=10000
    PLEASE NOTE:
    I made an error in creating the INI file and did not realize it until after. The MB in the key name is mislabeled. It should be in bytes.
    Please DO NOT edit the keys in the INI file - they need to stay the same.
    You will only have to change this ONCE.
    So the actual file should be:
    [Settings]
    debugLogMaxSizeLinuxMB=500000000
    debugLogMaxSizeWindowsMB=10000000000
    This will set the debug log max size to 500MB for Linux and 10GB for Windows
    You can also set these values to any number of bytes you want and the next time you turn on debug logging in one of my plugins, the plugin will use these values for the max size of the debug logs.
    Cheers,
    Bob
    I am bumping this up..
    Everyone running my plugins should make sure they have done the steps in the first post at least once as this helps when I am trying to debug an issue
    Cheers,
    Bob
