HStouch display of VWS variable
  • HStouch display of VWS variable
    Hi Larry,
    I am using HS3 Pro and HStouch Designer. I love your VWS plug-in and it works perfectly with my Ambient VWS software and Davis Weather Station. I am trying to get Wind Speed to show in 1 second update time on a custom HSTouch screen and cannot figure out a way to do this. If I create a Text Box with the VWS plug-in value of Wind Speed in the StatusTrackingNormal property, I just get a static value that does not update. Do you have any ideas of how I can get Real Wind Speed to show as an active display on a HSTouch Screen. I am OK with some programming or other advanced solutions.
    Thanks.
    I am not familiar with how HSTouch works as I do not use it. Update intervals depends on Ambient VWS saving CSV's within your 1-second time frame and the plug-in (setup config) interval settings. You will find I'm sure that 1-second intervals will TAX both systems beyond there capabilities. Hopefully both VWS and HomeSeer are on the same computer and fairly beefy.
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
      Thanks for the help. I have other posts on HSTouch forums.
        Yes, both on same high end Alienware server and interval set to 2 sec
          Solved. CLOSED
