Problem with WhoIs
  • jon00
    Originally posted by jlikonen View Post
    Will there will be a HS3 version of Whois?
    I expect so. I have other things on the go at the moment so cannot say when.
  • jlikonen
    That did the trick. I forgot to register the dll when rebuilding my HS server. Also the date separator was wrong. Thanks a lot for your help. Will there will be a HS3 version of Whois?
  • jon00
    Open up a Command window (Cmd) with the prompt pointing to Homeseer's root directory.
    Type:
    Regsvr32 c2gwhois.dll
    This will re-register the dll and should solve your first issue.
    For the second, did you set the date separator character in the ini file correctly?
  • jlikonen
    I have had to rebuild my HS server and have now few problems with Whois. If I click IP address on the whois webpage I get following error message:
    Script error: ActiveX component can't create object: 'c2g.whois'Set wiobj = createobject("c2g.whois")wiobj.server="whois.ripe.net"
    I have checked that c2gwhois.dll is on the HS2 folder.
    Second problem is that if I make a search on the whois web page then I get following message:
    Script error: Type mismatch: '[string: "23.7.2013 21:15:51 "]' mymonth=Int(hs.StringItem(DateTime,1,DateSeparator)) Myday=Int(hs.StringItem(DateTime,2,DateSeparator))
    Any ideas?
  • travisdh
    Will do, from memory I have seen it even after hs restarts and the file is not read-only or anything like that.
  • jon00
    For some reason, it looks like the file has become locked. I would restart HS and then see if the problem persists.
  • travisdh
    Hi Jon00,
    I noticed in my logs that I am getting similar errors, what is causing these errors?
    3/31/2013 9:20:17 PM Jon00_Whois Error in subroutine main at block C (The process cannot access the file 'C:\HomeSeer HSPRO\Data\Whois\WebVisitsToday.log' because it is being used by another process.)
    3/31/2013 9:20:17 PM Jon00_Whois Error in subroutine Parselog at block C (Index was outside the bounds of the array.)
    3/31/2013 9:20:17 PM Jon00_Whois Error in subroutine Parselog at block B (Exception of type 'System.OutOfMemoryException' was thrown.)
    There is 3gb of ram on this virtual machine, and not all of it is being used (e.g. there is lots free). I did have this event running every five or so minutes, but have changed it to 15 minutes and it is still erroring up (there is also the 11:59 event as well).
  • jon00
    Originally posted by speedy View Post
    Fixed by changing DateFormatMMDDYY="0" in the whois.ini
    but still have two 01's in the date drop downs boxes for "from" & "to" on the web page ??
    Yes, that is correct. It will always show the date of the day when viewing the page in both boxes. It's just the way I wrote it to keep the filtering enabled all the time. If you actually just want to view todays visitors, notch up the 'to' date to a date in the future.
  • speedy
  • speedy
    Whois don't like 3-1-2010
    Jon,
    My whois vistors page doesn't like he date 3/1/2010...
    It only displays data from 2009 today ??
  • jon00
    It looks like it cannot find the Homeseer log file due to missing entries in the settings.ini
    Go to the Homeseer setup page and select the General tab.
    Look for Log File drop down box. Set this to the alternate setting and press save. Then put it back to what it should be and press save.
    Do the same for the Store logs in LOGS directory drop down.
    See if that solves the issue.
  • DJF3
    Darren-mc: how did it go? Everything working?
    Since about 1 day I have a similar issue:
    10-2-2010 4:14:49 Jon00_Whois Error in subroutine main at block C (The process cannot access the file 'C:\Program Files\HomeSeer 2\Data\Whois\WebVisitsToday.log' because it is being used by another process.)
    10-2-2010 4:14:49 Jon00_Whois Error in subroutine Parselog at block C (Index was outside the bounds of the array.)
    10-2-2010 4:14:49 Jon00_Whois Error in subroutine Parselog at block B (Could not find file 'C:\Program Files\HomeSeer 2\Logs\HomeSeer.LOG'.)
    The event runs every hour
  • darren-mc
    Ahh....I have two events...deleted one of them.
    Will see how that goes.
  • jon00
    Odd... how often have you set the event to update the data?
  • darren-mc
    Yes and I tried a re-install...just incase anything was wrong.
