No, Sir. This does not display. I don't even get the beep that says the sign got it. In the other script, the CID one you posted above, I do get the beep but nothing is displayed.
Jon00 LED Message Sign
OK,
I've just corrected the last bit of code as it was wrong.
Try this:
PHP Code:Sub Main(ByVal Parm As Object)
Dim Text As String = ""
Dim CIDNumber As String = ""
'CIDNumber = hsp.CIDNumber(1)
CIDNumber = "5551212"
Text="Call from{n}{sym5}" & CIDNumber & "{pause2}"
hs.runex ("jon00LEDMessageInput.vben","Main","|" & Text & "||")
end sub
Yes, Sir, that works - THANK YOU!!
Starting to learn the syntax. I have a friend of mine trying to make this into a "plugin" DOT NET style for me. If I can get it working, I will send it over to you if you are interested.Transitioning to HS3Pro .298 - WinXPEmbedded
Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
Hey Jon,
How are you, Sir?
Hoping to ask a small favor. Do you have the software that came with your sign? I can't find that tiny CD that came with mine and was hoping I can download it from you.Transitioning to HS3Pro .298 - WinXPEmbedded
BTW, this is the full protocol:
http://www.8051projects.net/files/pu...y_protocol.pdf
BTW, the REAL manufacturer is:
http://shirley8210.fm.alibaba.com/
And on this site, there is a LOT of information on it.
http://wls.wwco.com/ledsigns/m-500/Last edited by Dafunktyfunk; December 4, 2013, 09:05 PM.Transitioning to HS3Pro .298 - WinXPEmbedded
Originally posted by Dafunktyfunk View PostHey Jon,
How are you, Sir?
