I want to call a script when a certain pattern matches and pass the log line to the script as a parameter. Is this possible? P.S. I am still using HS2 - still waiting for a Caddx plugin upgrade! Thanks.
Question about passing parameter in Log Monitor
The pattern match is working fine. What I want to do is trigger a script and send the whole log line as a parameter. Here is what I am trying to do:
I sporadically get zwave errors - I have a large network that I optimize every night but these still keep cropping up - something I am going to chalk up to running HS2 at present.
When I get an error in the log, such as:
Failed sending Z-Wave command to device: Z-Wave Mud Room Mud Room Light (R15)
I use log monitor to trap the "Failed sending Z-Wave command to device:" to let me know that a device has not received the intended command.
I want to trigger a script and send the entire log line as a parameter. In the script I will then open the log file, find the line that was passed as a parameter, determine which device didn't respond, then step back through the log to see which command was sent to it, and then reissue the command. It's a little messy but, as I mentioned, until I can upgrade to HS3 I am hoping this will take care of things.
Does that make sense? Thanks.
