Problems installing mcsTemperature 4.8.2
  • Michael McSharry
    Only 1 post in the last 10 or so in this thread is visible to me. I see only the avatar and need to view source to see the text. I can read that you have some charting problems, but that is about all I can read. Email me a package with you mcsTemperature.ini and you database that contains the data that you are trying to view.
  • Mario from Spain
    Attached are my last config files and DB
  • Mario from Spain
    The forecast is not working (looks like it's not collecting data) and everynow and then I can see in the log:
    23/10/2003 20:52:04~!~mcsTemperature~!~UpdateForecastDevices 2 Overflow
    23/10/2003 20:52:04~!~mcsTemperature~!~ GetWeather into C:\Archivos de programa\HomeSeer\mcsTemperature.mdb Forecast with Progress 9
  • Mario from Spain
    hummm! Fast support! Superb!
    I looks like it's getting data into the database, but there are some issues I can see:
    - When the Temperature.asp is shown this appears in the log:
    23/10/2003 20:33:28~!~mcsTemperature Debug~!~Data Elements=360, Data Names=3
    23/10/2003 20:33:28~!~mcsTemperature Debug~!~Draw CD Chart X axis dataIndex limit of 360 exceeded with 420 for index 7 and time delta of 1
    23/10/2003 20:33:28~!~mcsTemperature Debug~!~X Axis Data Completed
    23/10/2003 20:33:28~!~mcsTemperature Debug~!~Y Axis Data Completed
    I guess it's not very important, but... just in case.
    The only working graphic is "LinSel" any other just gives a black scren (with menus, etc...).
    Triying "Table" or "Color" or "LinTab" or "All" I get this in the log:
    23/10/2003 20:37:20~!~mcsTemperature Debug~!~FormatTemperatureScreen Progress 0
    23/10/2003 20:37:20~!~mcsTemperature Debug~!~FormatTemperatureScreen Progress 5, Sensor Count=3
    23/10/2003 20:37:20~!~mcsTemperature Debug~!~FormatTemperatureScreen Progress 6 SELECT Avg(CSVInsideTemperature) AS Rave, Min(CSVInsideTemperature) AS Rmin, Max(CSVInsideTemperature) AS Rmax FROM Temperature WHERE SampleDate >=#2003-10-23 15:00# AND SampleDate < #2003-10-23 21:00# AND CSVInsideTemperature<>0 AND (not isNull(CSVInsideTemperature))
    23/10/2003 20:37:20~!~mcsTemperature~!~ FormatTemperatureScreen: La operación en varios pasos generó errores. Compruebe los valores de estado.
    "La operación en varios pasos generó errores. Compruebe los valores de estado." minds something like "The process in more than one steeps" (or stages, something like a transaction) "generated errors. Check the state values".
    Triying "Line" I get:
    23/10/2003 20:45:44~!~mcsTemperature Debug~!~FormatTemperatureScreen Progress 0
    23/10/2003 20:45:44~!~mcsTemperature Debug~!~Chart SQL=
    23/10/2003 20:45:44~!~mcsTemperature Debug~!~Chart SQL2=
    23/10/2003 20:45:44~!~mcsTemperature Debug~!~Chart SQL3=
    23/10/2003 20:45:44~!~mcsTemperature Debug~!~Draw CD Chart X axis dataIndex limit of 360 exceeded with 420 for index 7 and time delta of 1
    23/10/2003 20:45:44~!~mcsTemperature Debug~!~X Axis Data Completed
    23/10/2003 20:45:44~!~mcsTemperature Debug~!~Y Axis Data Completed
    These error happened always (with every old version of the plugin and configuration I tried in the last few days).
  • Michael McSharry
    I suspect that you do not want to import all the fields from the data file and many of those have no value to be stored in the database. The time-stamp may be interesting for the virtual device so you can monitor that the data file is being updated, but likely no need to store it to the database. Any device type of Text probably should not be stored to the database since it will not be used in the charting. When data is stored to the database it puts its own timestamp and that is the time that is used for the x-axis.
    I'd have to review the manual, but I believe an entry with a blank virtual device definition is ignored and blank database name is not written to the database. I think the "show in chart" field value of the definition is ignored since that is now controlled from the Trend Group setup. Even though ignored, its positional existence is still expected to maintain backward compatibility.
  • Michael McSharry
    This must be a limitation of the VB text box control. What I will do is see if the entry is a filename and if so then read from the file to get the layout definition rather than parsing the line directly. That way short definitions can be done just like now, but longer ones have a way to be entred as well. I'll make the file input ignore the CR and LF characters so they can be entred with one field per line which I find easier to read and edit. It is posted as V4.10.6
  • Mario from Spain
    Finally it looks like we are on the right path!
    I updated the exe and the ini and things are now working (more or less).
    I guess the field to store "Input File 1" is somewhat short and have no room for the definition of the 39 devices. It permits to write in the text field but when I press the update button it cuts the field (and is cutted also in the ini file).
    I was able to store some more by shortening the field names taking away the "CSV" part of the names but still not enougth.
    If it's not easy to make it longer I can short the fied names but then it will be not very intuitive.
    Weel, we are two steeps from the total fix!
  • Michael McSharry
    The CSV processing was changed to ignore fields beyond those that are specified in the definition string. It saw 38 fields in the test file with 21 in the definition string. There were some problems in the code as well that I cleaned up.
    There are two rain-related fields for which mcsTempeature does not have direct mapping. The only rain-related types are daily accumulation and rain rate. I suspect that if you define total rain as a daily rain type then mcsTempeature will try to reset it to zero at midnight.
    The device types have grown since the list was published. It is shown here for reference.
    <pre class="ip-ubbcode-code-pre">
    Public Const jTemperature As Integer = 0
    Public Const jWindDirection As Integer = 1
    Public Const jWindSpeed As Integer = 2
    Public Const jWindGust As Integer = 3
    Public Const jRainToday As Integer = 4
    Public Const jRainRate As Integer = 5
    Public Const jHumidity As Integer = 6
    Public Const jHumidityRate As Integer = 7
    Public Const jBarometer As Integer = 8
    Public Const jBarometerRate As Integer = 9
    Public Const jLightning As Integer = 10
    Public Const jSwitch As Integer = 11
    Public Const jRelay As Integer = 12
    Public Const jIndex As Integer = 13
    Public Const jDistance As Integer = 14
    Public Const jUser0 As Integer = 15
    Public Const jUser1 As Integer = 16
    Public Const jUser2 As Integer = 17
    Public Const jUser3 As Integer = 18
    Public Const jThermocron As Integer = 19
    Public Const jVoltage As Integer = 20
    Public Const jVoltage2 As Integer = 21
    Public Const jThermostat As Integer = 22
    Public Const jMoisture As Integer = 23
    Public Const jMinutes As Integer = 24
    Public Const jStatus As Integer = 25
    Public Const jRainMonth As Integer = 26
    Public Const jDewPoint As Integer = 27
    Public Const jText As Integer = 28
    Public Const jGallonToday As Integer = 29
    Public Const jGallonRate As Integer = 30
    </pre>
  • Mario from Spain
    I just sent you the CSV file.
    Also I changed to usecsv=false but I'm still getting:
    22/10/2003 23:38:56~!~mcsTemperature~!~Setup Load with Progress 14 Invalid property value
    22/10/2003 23:39:10~!~mcsTemperature~!~Setup Page did not load properly so no changes were made
    MANY THANKS, Michael!
    Mario.-
  • Michael McSharry
    Could you email me your csv file so I have something real to test with.
    Also you can edit the ini file and change the useCSV key to be false.
    There are three of them
    </pre>
  • Mario from Spain
    Michael,
    I upgraded to 4.10.4 and tried to import from the CSV file.
    In Devices/files, "Imput File 1", I entered the line:
    ,\1,CSVFileVersion,14,0,\2,CSVYear,14,0,\3,CSVMonth,14,0,\4, CSVDay,14,0,\5,CSVHour,14,0,\6,CSVMinute,14,0,\7,CSVSecond,1 4,0,\8,CSVWindSpeed,2,1,\9,CSVWindGust,3,1,\10,CSVWindDirect ion,1,1,\11,CSVInsideHumidity,6,1,\12,CSVOutsideHumidity,6,1 ,\13,CSVInsideTemperature,0,1,\14,CSVOutsideTemperature,0,1, \15,CSVBarometer,8,1,\16,CSVTotalRain,4,1,\17,CSVDailyRain,4 ,1,\18,CSVHourlyRain,4,1,\19,CSVWeatherCondition,14,1,\20,CS VChannel1Temperature,0,1,\21,CSVChannel1Humidity,6,1,\22,CSV Channel2Temperature,0,0,\23,CSVChannel2Humidity,6,0,\24,CSVC hannel3Temperature,0,0,\25,CSVChannel3Humidity,6,0,\26,CSVEv apotranspiration,14,0,\27,CSVUVIndex,14,0,\28,CSVSolarRadiat ion,14,0,\29,CSVWindChild,0,1,\30,CSVIndorHeatIndex,0,1,\31, CSVOutdoorHeatIndex,0,1,\32,CSVDewPoint,0,1,\33,CSVRainRate, 5,1,\34,CSVOutdoorTempRate,0,1,\35,CSVIndoorTempRate,0,1,\36 ,CSVBarometerRate,9,1,\37,CSVChannel1TempRate,0,1,\38,CSVCha nnel2TempRate,0,0,\39,CSVChannel3TempRate,0,0
    Before pressing the update button I checked "General Debug Log" and this is what happened:
    22/10/2003 20:22:40~!~mcsTemperature~!~ DoCSVMap: Subscript out of range
    22/10/2003 20:22:41~!~mcsTemperature~!~Creating database fields CSVWindGust,CSVMinute,CSVInsideHumidity,CSVWindDirection,CSV OutsideTemperature,CSVFileVersion,CSVYear,CSVMonth,CSVDay,CS VHour,CSVBarometer,CSVTotalRain,CSVDailyRain,CSVHourlyRain,C SVChannel1Temperature,CSVChannel1Humidity,CSVChannel2Tempera ture,CSVChannel2Humidity,CSVChannel3Temperature,CSVChannel3H umidity,CSVEvapotranspiration,CSVUVIndex,CSVSolarRadiation,C SVWindChild,CSVIndorHeatIndex,CSVOutdoorHeatIndex,CSVDewPoin t,CSVRainRate,CSVOutdoorTempRate,CSVIndoorTempRate,CSVBarome terRate,CSVChannel1TempRate,CSVChannel2TempRate,CSVChannel3T empRate in C:\Archivos de programa\HomeSeer\mcsTemperature.mdb\Temperature
    22/10/2003 20:22:41~!~mcsTemperature Debug~!~Setup Page Unload
    22/10/2003 20:23:33~!~mcsTemperature Debug~!~Database Timer=1
    22/10/2003 20:23:33~!~mcsTemperature Debug~!~setIO ]60 from 0 to 19
    22/10/2003 20:23:33~!~mcsTemperature Debug~!~Log Temperature Sensor Count=39, INSERT INTO Temperature(SampleDate,OutsideTemp,InsideTemp,CSVWindGust,VW SWindSpeed,VWSWindGust,CSVMinute,CSVInsideHumidity,CSVWindDi rection,CSVOutsideTemperature,Ch1Temperature,CSVFileVersion, CSVYear,CSVMonth,CSVDay,CSVHour,CSVBarometer,CSVTotalRain,CS VDailyRain,CSVHourlyRain,CSVChannel1Temperature,CSVChannel1H umidity,CSVChannel2Temperature,CSVChannel2Humidity,CSVChanne l3Temperature,CSVChannel3Humidity,CSVEvapotranspiration,CSVU VIndex,CSVSolarRadiation,CSVWindChild,CSVIndorHeatIndex,CSVO utdoorHeatIndex,CSVDewPoint,CSVRainRate,CSVOutdoorTempRate,C SVIndoorTempRate,CSVBarometerRate,CSVChannel1TempRate,CSVCha nnel2TempRate,CSVChannel3TempRate) SELECT #2003-10-22 20:23:33# AS QT,84000 AS Q0,220000 AS Q1,830000 AS Q2,60000 AS Q3,150000 AS Q4,0 AS Q5,780000 AS Q6,4800 AS Q7,1,00704E+07 AS Q8,208000 AS Q9,0 AS Q10,0 AS Q11,0 AS Q12,0 AS Q13,0 AS Q14,940000 AS Q15,0 AS Q16,0 AS Q17,0 AS Q18,470000 AS Q19,0 AS Q20,0 AS Q21,0 AS Q22,0 AS Q23,0 AS Q24,0 AS Q25,0 AS Q26,75000 AS Q27,223000 AS Q28,106000 AS Q29,48000 AS Q30,0 AS Q31,-24000 AS Q32,8000 AS Q33,7900 AS Q34,1000 AS Q35,1000 AS Q36,1000 AS Q37,0 AS Q38
    22/10/2003 20:23:33~!~mcsTemperature Debug~!~Change Field because El número de valores de consulta y el número de campos de destino son diferentes., error number=-2147217900, Fields=OutsideTemp,5,InsideTemp,6,CSVWindGust,6,VWSWindSpeed ,5,VWSWindGust,6,CSVMinute,1,CSVInsideHumidity,6,CSVWindDire ction,4,CSVOutsideTemperature,11,Ch1Temperature,6,CSVFileVer sion,1,CSVYear,1,CSVMonth,1,CSVDay,1,CSVHour,1,CSVBarometer, 6,CSVTotalRain,1,CSVDailyRain,1,CSVHourlyRain,1,CSVChannel1T emperature,6,CSVChannel1Humidity,1,CSVChannel2Temperature,1, CSVChannel2Humidity,1,CSVChannel3Temperature,1,CSVChannel3Hu midity,1,CSVEvapotranspiration,1,CSVUVIndex,1,CSVSolarRadiat ion,5,CSVWindChild,6,CSVIndorHeatIndex,6,CSVOutdoorHeatIndex ,5,CSVDewPoint,1,CSVRainRate,6,CSVOutdoorTempRate,4,CSVIndoo rTempRate,4,CSVBarometerRate,4,CSVChannel1TempRate,4,CSVChan nel2TempRate,4,CSVChannel3TempRate,1
    Now when I try to load the mcsTemperature menu to change the CSV definition I get:
    22/10/2003 20:32:09~!~mcsTemperature Debug~!~Database Timer=1
    22/10/2003 20:32:09~!~mcsTemperature Debug~!~setIO ]60 from 0 to 19
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 2
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 3
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 4
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 5
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 6
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 7.5-
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\13=OutsideTemp,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\12=InsideTemp,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\9=CSVWindGust,3,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\7=VWSWindSpeed,2,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\8=VWSWindGust,3,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\6=CSVMinute,14,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\11=CSVInsideHumidity,6,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\10=CSVWindDirection,1,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\14=CSVOutsideTemperature,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\19=Ch1Temperature,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\1=CSVFileVersion,15,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\2=CSVYear,14,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\3=CSVMonth,14,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\4=CSVDay,14,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\5=CSVHour,14,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\15=CSVBarometer,8,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\16=CSVTotalRain,4,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\17=CSVDailyRain,4,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\18=CSVHourlyRain,4,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\20=CSVChannel1Temperature,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\21=CSVChannel1Humidity,6,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\22=CSVChannel2Temperature,0,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\23=CSVChannel2Humidity,6,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\24=CSVChannel3Temperature,0,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\25=CSVChannel3Humidity,6,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\26=CSVEvapotranspiration,14,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\27=CSVUVIndex,14,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\28=CSVSolarRadiation,14,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\29=CSVWindChild,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\30=CSVIndorHeatIndex,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\31=CSVOutdoorHeatIndex,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\32=CSVDewPoint,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\33=CSVRainRate,5,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\34=CSVOutdoorTempRate,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\35=CSVIndoorTempRate,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\36=CSVBarometerRate,9,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\37=CSVChannel1TempRate,0,1
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\38=CSVChannel2TempRate,0,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 8-\39=CSVChannel3TempRate,0,0
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 9
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 10
    22/10/2003 20:32:54~!~mcsTemperature Debug~!~Setup Load Progress 10.1
    22/10/2003 20:32:55~!~mcsTemperature~!~Setup Load with Progress 14 Invalid property value
    And when I try to exit, after making the changes, I get:
    22/10/2003 20:33:05~!~mcsTemperature~!~Setup Page did not load properly so no changes were made
    So now, total collapse!! Plugin isn't working and I cant't change anything.
    I already tried deleting in mcsTemperature.ini the line:
    CSVFormat: ,\1,CSVFileVersion,14,0,\2,CSVYear,14,0,\3,CSVMonth,14,0,\4, CSVDay,14,0,\5,CSVHour,14,0,\6,CSVMinute,14,0,\7,CSVSecond,1 4,0,\8,CSVWindSpeed,2,1,\9,CSVWindGust,3,1,\10,CSVWindDirect ion,1,1,\11,CSVInsideHumidity,6,1,\12,CSVOutsideHumidity,6,1 ,\13,CSVInsideTemperature,0,1,\14,CSVOutsideTemperature,0,1, \15,CSVBarometer,8,1,\16,CSVTotalRain,4,1,\17,CSVDailyRain,4 ,1,\18,CSVHourlyRain,4,1,\19,CSVWeatherCondition,14,1,\20,CS VChannel1Temperature,0,1,\21,CSVChannel1Humidity,6,1,\22,CSV Channel2Temperature,0,0,\23,CSVChannel2Humidity,6,0,\24,CSVC hannel3Temperature,0,0,\25,CSVChannel3Humidity,6,0,\26,CSVEv apotranspiration,14,0,\27,CSVUVIndex,14,0,\28,CSVSolarRadiat ion,14,0,\29,CSVWindChild,0,1,\30,CSVIndorHeatIndex,0,1,\31, CSVOutdoorHeatIndex,0,1,\32,CSVDewPoint,0,1,\33,CSVRainRate, 5,1,\34,CSVOutdoorTempRate,0,1,\35,CSVIndoorTempRate,0,1,\36 ,CSVBarometerRate,9,1,\37,CSVChannel1TempRate,0,1,\38,CSVCha nnel2TempRate,0,0,\39,CSVChannel3TempRate,0,0
    And changing the sensor type from 14 to 11 but it didnt solved the problem.
    Attached is my actual ini file.
    arghhh!!
  • Michael McSharry
    I looked at it and saw it to be a very easy update to handle the decimal replacement during CSV inputs. The box to specify the replacemement characerter moved from the Temp05 tab to the Interface Tab or Version 4.10.4.
    Do note that CSV inputs was a feature very early in the plugin and much has changed over the months. This code has not been exercised to the best of my knowledge in a long time.
  • Michael McSharry
    If it does not do it now, then I can make it do it. It is just like doing it with the Temp05 when I read the dots from it. Let me know if this is the route you want to go. I don't want to do something that nobody is going to use.
  • Mario from Spain
    The CSV file VWS writes already has the dots. It's:
    1.00,2003,10,21,15,56,48,7,13,88,56,81,19.1,13.5,1007.04,93. 00,0.00,0.00,0,19.0,49,0.0,0,0.0,0,0.00,0.0,0,13.3,19.9,15.9 ,10.3,0.000,-0.4,-0.2,-0.20,-0.3,-0.3,-0.3
    So I guess if I let mcsTemperature populate the virtual devices from this text file it will not change the dots into commas, isn't it?
  • Michael McSharry
    It does look like you have identified the problem being the period in the device string when your regional settings indicate that a comma should be used. This is really a problem with the VWS plugin not paying attention to the regional settings. I know I had a lot of difficulty in the beginning with number formats and with date formats.
    mcsTemperature does have a check for data that it inputs from the Temp05 since the Temp05 always returns a period. This is done before it stores the result into a virtual device. Once data is stored in a virtual device it should be pristine with proper formatting and proper unit conversions.
    I tink you need to pursue the VWS plugin to get it to produce the correct data rather than expecting mcsTemperature to clean it up. Virtual device data is used for trigger conditions, control decisions via mcsControlSystems, and it is used for storage to the database for trending. Since your input into a virtual device is asychronous to the database storage, trigger algorithms, and the control algorithms there is no good time for mcsTemperature to fix it.
    You may also have an option of letting mcsTemperature populate the virtual device from the text file. I'm not aware of anyone who is using this capability, but it was designed for applications such as this. At least then if there are regional setting proplems I can handle them before the data gets into virtual device.
