Using mcsTemperature to track energy usage
  • Mario from Spain
    We are really close now!!! Almost everything is working!
    The change to the semicolon delimiter solved all the issues with the regional settings and the counters looks ok and are saving coherent data to the database.
    The second counter wasn't visible at first, more on this at the end...
    The rate is computed as the moving average of the last three samples.
    I think it's not desirable as the minimum period beetween samples is already one minute and in one minute we have a lot of pulses to smoth the measure.
    With a moving average of three munutes it looks very slow.
    The devicevalue will contain the desired value scaled by 100. You should not usually be getting 0.
    I still can't get any value other than 0. I'm using MsgBox hs.DeviceValue("]34") to look at the DeviceValue.
    If you delete your watt history key, then it should recreate it without the large starting bias. Previously it assumed the counter starts at 0 so it installed one that was not there then the first day's readings will be very high. You can also just edit the last value in the watt history key to align with your current reading. The last entry is the midnight reading
    This is working right... but only with one counter...
    Two counters:
    At first I just deleted the watt_history key, saved the new exe and tried. Everything was working fine without any sign of the counter 14.
    Then I deleted watt_history, [devices] and [database] section the plugin recreated the devices but I think it mixed the data beetween the two counters (counter 14 has a value of 2 I manualy set):
    30/03/2005 2:55:41~!~mcsTemperature Debug~!~DS9x9x Port <COM9> Device = DS18B20 A7000000318E2828
    30/03/2005 2:55:43~!~mcsTemperature Debug~!~ DS18B20(1):
    30/03/2005 2:55:44~!~mcsTemperature Debug~!~DS9x9x Port <COM9> Device = DS2423 8A000000052B521D
    30/03/2005 2:55:44~!~mcsTemperature~!~Creating database fields s8A000000052B521DW in C:\Archivos de programa\HomeSeer\mcsTemperature.mdb\TemperatureNew7
    30/03/2005 2:55:44~!~mcsTemperature~!~Creating database fields s8A000000052B521DG in C:\Archivos de programa\HomeSeer\mcsTemperature.mdb\TemperatureNew7
    30/03/2005 2:55:44~!~mcsTemperature~!~Creating database fields s8A000000052B521DN1 in C:\Archivos de programa\HomeSeer\mcsTemperature.mdb\TemperatureNew7
    30/03/2005 2:55:44~!~mcsTemperature~!~Creating database fields s8A000000052B521DC1 in C:\Archivos de programa\HomeSeer\mcsTemperature.mdb\TemperatureNew7
    30/03/2005 2:55:44~!~mcsTemperature Debug~!~Wind Speed Counter=57932, Prior Counter=, Interval=0 seconds
    30/03/2005 2:55:44~!~mcsTemperature Debug~!~Water Counter=2, Prior Counter=0, Interval=1,654665E+08 seconds
    30/03/2005 2:55:44~!~mcsTemperature Debug~!~^44 Water Delta Seconds=1,654665E+08, Prior Value=0, Current Value=2, Rate=4,351333E-06
    Later a error
    30/03/2005 2:55:58~!~mcsTemperature~!~CreateTemperatureTable: Error #-2147217856 on line 400 Ha intentado bloquear la tabla '' al abrirla, pero no se puede bloquear porque actualmente está en uso. Espere un momento y vuelva a intentar la operación.
    Minds: Tried to lock the table " at opening, but is not possible to lock as it's now in use. Wait a moment and retry.
    Later the two counter values are mixed:
    30/03/2005 2:56:09~!~mcsTemperature Debug~!~Water Counter=57934, Prior Counter=2, Interval=25 seconds
    30/03/2005 2:56:09~!~mcsTemperature Debug~!~^65 Water Delta Seconds=25, Prior Value=2, Current Value=57934, Rate=834220,8
    And now I see a new device (8A000000052B521DN without the "1" at the end)!
    30/03/2005 2:57:29~!~mcsTemperature Sensor Info~!~A7000000318E2828, HS:]2, Index:97, DB:tA7000000318E2828,0,1
    30/03/2005 2:57:29~!~mcsTemperature Sensor Info~!~8A000000052B521DW, HS:]65, Index:97, DB:s8A000000052B521DW,2,1
    30/03/2005 2:57:29~!~mcsTemperature Sensor Info~!~8A000000052B521DG, HS:]66, Index:97, DB:s8A000000052B521DG,3,1
    30/03/2005 2:57:29~!~mcsTemperature Sensor Info~!~8A000000052B521DN1, HS:^44, Index:97, DB:s8A000000052B521DN1,29,1
    30/03/2005 2:57:29~!~mcsTemperature Sensor Info~!~8A000000052B521DC1, HS:^45, Index:97, DB:s8A000000052B521DC1,30,1
    30/03/2005 2:57:29~!~mcsTemperature Sensor Info~!~8A000000052B521DN, HS:^65, Index:97, DB:s8A000000052B521DN,29,1
    And after this all was messed with each minute (each write to the db):
    30/03/2005 3:03:57~!~mcsTemperature Debug~!~Log Temperature Sensor Count=44, INSERT INTO TemperatureNew7(SampleDate,CSVYear,CSVMonth,CSVDay,CSVHour,CSVMinute,CSVSecond,CSVWindSpeed,CSVWindGust,CSVWindDirection,CSVInsideHumidity,CSVOutsideHumidity,CSVInsideTemperature,CSVOutsideTemperature,CSVBarometer,CSVTotalRain,CSVDailyRain,CSVHourlyRain,CSVWeatherCondition,CSVChannel1Temperature,CSVChannel1Humidity,CSVChannel2Temperature,CSVChannel2Humidity,CSVChannel3Temperature,CSVChannel3Humidity,CSVEvapotranspiration,CSVUVIndex,CSVSolarRadiation,CSVWindChild,CSVIndorHeatIndex,CSVOutdoorHeatIndex,CSVDewPoint,CSVRainRate,CSVOutdoorTempRate,CSVIndoorTempRate,CSVBarometerRate,CSVChannel1TempRate,CSVChannel2TempRate,CSVChannel3TempRate,tA7000000318E2828,s8A000000052B521DW,s8A000000052B521DG,s8A000000052B521DN1,s8A000000052B521DC1,s8A000000052B521DN) SELECT #2005-03-30 3:03:57# AS QT,200500 AS Q0,300 AS Q1,3000 AS Q2,300 AS Q3,300 AS Q4,0 AS Q5,700 AS Q6,1000 AS Q7,1000 AS Q8,4500 AS Q9,7000 AS Q10,2180 AS Q11,700 AS Q12,101804 AS Q13,4000 AS Q14,0 AS Q15,0 AS Q16,0 AS Q17,0 AS Q18,0 AS Q19,2210 AS Q20,3800 AS Q21,0 AS Q22,0 AS Q23,0 AS Q24,0 AS Q25,0 AS Q26,570 AS Q27,2200 AS Q28,860 AS Q29,190 AS Q30,0 AS Q31,-30 AS Q32,-20 AS Q33,34 AS Q34,0 AS Q35,0 AS Q36,0 AS Q37,2240 AS Q38,0 AS Q39,0 AS Q40,0 AS Q41,0 AS Q42,24848 AS Q43
    30/03/2005 3:03:57~!~mcsTemperature Debug~!~Change Field because La instrucción INSERT INTO contiene el siguiente nombre de campo desconocido: 's8A000000052B521DN'. Asegúrese de que ha escrito correctamente el nombre y vuelva a intentar la operación., error number=-2147217900, Fields=CSVYear,6,CSVMonth,3,CSVDay,4,CSVHour,3,CSVMinute,3,CSVSecond,1,CSVWindSpeed,3,CSVWindGust,4,CSVWindDirection,4,CSVInsideHumidity,4,CSVOutsideHumidity,4,CSVInsideTemperature,4,CSVOutsideTemperature,3,CSVBarometer,6,CSVTotalRain,4,CSVDailyRain,1,CSVHourlyRain,1,CSVWeatherCondition,1,CSVChannel1Temperature,1,CSVChannel1Humidity,1,CSVChannel2Temperature,4,CSVChannel2Humidity,4,CSVChannel3Temperature,1,CSVChannel3Humidity,1,CSVEvapotranspiration,1,CSVUVIndex,1,CSVSolarRadiation,1,CSVWindChild,3,CSVIndorHeatIndex,4,CSVOutdoorHeatIndex,3,CSVDewPoint,3,CSVRainRate,1,CSVOutdoorTempRate,3,CSVIndoorTempRate,3,CSVBarometerRate,2,CSVChannel1TempRate,1,CSVChannel2TempRate,1,CSVChannel3TempRate,1,tA7000000318E2828,4,s8A000000052B521DW,1,s8A000000052B521DG,1,s8A000000052B521DN1,1,s8A000000052B521DC1,1,s8A000000052B521DN,5
    30/03/2005 3:03:57~!~mcsTemperature~!~Database field s8A000000052B521DN is being created
    30/03/2005 3:03:59~!~mcsTemperature~!~ Resize Fields: on line 820 Ha intentado bloquear la tabla '' al abrirla, pero no se puede bloquear porque actualmente está en uso. Espere un momento y vuelva a intentar la operación.
    I think we can concentrate first on the moving average and the DeviceValue and then we can move to make the two counters work.
    Attached is the ini after the mess just in case it has any important information.
    I reverted to the ini file before this and everything is working fine again with just one counter.
  • Michael McSharry
    Yes, I picked up on the use of comma rather than period for the decimal was causing a problem. I changed the ini key to use semicolon as a delimiter. I also added access to the second counter which invloved quite a number of changes. If you have a way to stimulate counter 14 then give it a try. If you have a problem at first, then edit your ini file to remove the existing definition of this counter in both the [devices] and [database] section. This may be necessary for it to see the second counter, but I think it will find it anyway.
    If you delete your watt history key, then it should recreate it without the large starting bias. Previously it assumed the counter starts at 0 so it installed one that was not there then the first day's readings will be very high. You can also just edit the last value in the watt history key to align with your current reading. The last entry is the midnight reading.
  • Mario from Spain
    After some more testing:
    It looks to me as the regional settings has something to do with this issue.
    I have changed the regional settings to "English US" and it looks like it's working (more or less).
    Now "Wattage today" shows 54520 (the raw counter value) and right now "Wattage Rate" shows "Use at 654.42 watt/hr"
    I think Wattage today should be substracting the counter value at midnight.
    Edit: Now, after midnight, it's showing just the today value
    watt_history=,,510.9208,,56543,3/30/2005 12:44:23 AM,56159
    "Wattage Rate" appears to be some kind of average (hourly?) and not the actual rate. If I turn on a heat pump, I can see the rate value increasing very slowly.
    While you have some time to fix this, I'm triying to write an script to work out the values but, how should I extract the values from the devices?
    If I use:
    hs.DeviceString("]34") I get the value but with a lot of html code
    hs.DeviceValue("]34") I get 0
    hs.DeviceStatus("]34") I get 17
    Now the entry in the ini file is: watt_history=,,1881.712,,54805,3/29/2005 9:48:40 PM,0
    REM: Maybe the strange readings I was getting with mcsControlsystems is also because of the regional settings?
    We are close to have this working!!!
  • Mario from Spain
    Yes, I posted the ini before changing it to type 7 and 8
    Now there is the entry:
    watt_history=,,12,6,,49738,29/03/2005 8:45:06,49738
    The log at midnight show:
    28/03/2005 23:59:58~!~mcsTemperature Debug~!~DS9x9x Port <COM9>Device = DS18B20 A7000000318E2828
    28/03/2005 23:59:59~!~mcsTemperature Debug~!~setIO ]1 from 0 to 19
    28/03/2005 23:59:59~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9> Address=A7000000318E2828 Family=DS18B20 Temperature=16,75
    28/03/2005 23:59:59~!~mcsTemperature Debug~!~DS9x9x Port <COM9>Device = DS2423 8A000000052B521D
    28/03/2005 23:59:59~!~mcsTemperature Debug~!~Water Counter=47427, Prior Counter=47427, Interval=2700 seconds
    28/03/2005 23:59:59~!~mcsTemperature Debug~!~]34 Water Delta Seconds=2700, Prior Value=47427, Current Value=47427, Rate=22,5
    28/03/2005 23:59:59~!~mcsTemperature Debug~!~setIO ]35 from 0 to 19
    29/03/2005 0:00:00~!~mcsTemperature Debug~!~setDevice ]35 from 2 to 2
    29/03/2005 0:00:00~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9> Address=8A000000052B521D Family=DS2423 Counter=47427
    Right now the counter value as reported in the log is 49767. The house power comsumption tonight should go about 0.3 kWh as there is on just the fridge and the HomeSeer PC.
    The interval in the log is always (for the last few hours) 2700
    I'm attaching the actual ini file and a complete 5 minute log with HS start and shut down.
    I'm reading counter 15. I believe AAG connects both counters in their wind instrument and in the counter module together. I could be wrong, but counter 15 is the one that works for both pieces of equipment.
    I'm using counter 15 for this but both counters are independent and are not connected together. In the future I would like to use counter 14 for wather.
  • Michael McSharry
    I looked at your ini file and I did not see any keys to show history of the counters. For the wattage there should be a key "watt_history". Could it be that you posted it before a few cycles of collecting data with the suffix set to 7 and 8? If this is not the case then look in the log for any error message that may indicate that the ComputeWaterCount procedure has an error and did not complete to the end.
    The interval you pointed out is based upon the "watt_history" line from the ini file. There are 7 entries on that line. The last is the sensor reading at midnight at the start of the day. The one before that is the time when the prior reading was processed. The large number you posted is equivalent to 3 hours.
    The next step it to look in the ini file to see what is being recorded here for the "watt_history" key.
  • Michael McSharry
    You have given me so data to look into It's my turn now.
  • Mario from Spain
    After changing devices to
    [Devices]
    A7000000318E2828="]1,COM9,,,0"
    8A000000052B521D7="]34,,,,0"
    8A000000052B521D8="]35,COM9,,,0"
    the device ]35 shows Use at xx watt/hr but the values are still wrong.
    The log is always like
    28/03/2005 0:02:40~!~mcsTemperature Debug~!~Water Counter=36136, Prior Counter=36136, Interval=10800 seconds
    With "Water Counter" (maybe just a cosmetic error?). Water Counter and Prior Counter shown always same value. Interval looks like a wrong value (the interval beetween counter reads is 62 seconds). The device status show things like Use at 25,2 watt/hr (right now it should be arround 600/800).
  • Michael McSharry
    My mistake on the sensor ID. The ends should be D7 and D8. I had miscounted the number of characters. The 7 and 8 are wattage and wattage rate. The prior W and G were wind speed and gust
  • Mario from Spain
    I changed s8A000000052B521DG to s8A000000052B5217 and s8A000000052B521DW to s8A000000052B5218 but then mcsTemperature do not show the sensor.
    I looked at the ID with OneWireViewer and it identifies the sensor as s8A000000052B521D. Also in the log I can see this:
    PHP Code:
    27/03/2005 21:50:26~!~mcsTemperature Debug~!~DS9x9x Port <COM9Device DS18B20 A7000000318E2828
    27
    /03/2005 21:50:26~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9Address=A7000000318E2828 Family=DS18B20 Temperature=21,875
    27
    /03/2005 21:50:26~!~mcsTemperature Debug~!~DS9x9x Port <COM9Device DS2423 8A000000052B521D
    27
    /03/2005 21:50:27~!~mcsTemperature Debug~!~ DS2423
    27
    /03/2005 21:50:27~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9Address=8A000000052B521D Family=DS2423
    27
    /03/2005 21:50:27~!~Info~!~ Web Server authorized local login successful from127.0.0.1 UserMario
    27
    /03/2005 21:50:37~!~mcsTemperature Debug~!~DS9x9x Port <COM9Device DS18B20 A7000000318E2828
    27
    /03/2005 21:50:38~!~mcsTemperature Debug~!~setIO ]1 from 0 to 19
    27
    /03/2005 21:50:38~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9Address=A7000000318E2828 Family=DS18B20 Temperature=21,8125
    27
    /03/2005 21:50:38~!~mcsTemperature Debug~!~DS9x9x Port <COM9Device DS2423 8A000000052B521D
    27
    /03/2005 21:50:38~!~mcsTemperature Debug~!~ DS2423
    27
    /03/2005 21:50:38~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9Address=8A000000052B521D Family=DS2423
    27
    /03/2005 21:50:48~!~mcsTemperature Debug~!~DS9x9x Port <COM9Device DS18B20 A7000000318E2828
    27
    /03/2005 21:50:49~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9Address=A7000000318E2828 Family=DS18B20 Temperature=21,8125
    27
    /03/2005 21:50:49~!~mcsTemperature Debug~!~DS9x9x Port <COM9Device DS2423 8A000000052B521D
    27
    /03/2005 21:50:49~!~mcsTemperature Debug~!~ DS2423
    27
    /03/2005 21:50:49~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9Address=8A000000052B521D Family=DS2423
    There is one more thing I don't understand: The DS2423 has two counters. How do you know if you are reading one or the other? (And where you setup wich one to read?).
    where is wk mins displayed?
    I mind in the sprinkler controller web page. You can read about that in this thread http://forums.homeseer.com/showpost....04&postcount=1 but I think I was wrong and you had some other thing in mind.
    I recall now that I sample the wind speed at 15 second intervals to get a reasonable gust calculation. Once we get past the basic integration of the energy counter then I can add the a 1 minute sample rate for it to populate virtual device. The database recording rate will still be the same as the other sensors as specified in the setup page. You can let me know if this is of any value to you.
    I think with this will be very usefull as then we would make al the calculations and write the accumulated fields with a script.
  • Michael McSharry
    The sensor ID sould be 17 characters and yours are 18 with the type position as "D" which is a wind direction. I need to look at why the wattage type selection is not updating the sensor type. If you want to play then change the ini file values for s8A000000052B521DG to s8A000000052B5217 and s8A000000052B521DW to s8A000000052B5218. This should allow it to process the sensor as wattage. The database filed name does not matter.
    Do you mind the "Wk Mins" showing a wrong number? ...
  • Mario from Spain
    Originally posted by Michael McSharry
    What I have done is added Wattage as a native type for a counter. You will see it as an analog option. You will also see a Cal value in the Devices/Files.
    Great!
    I can see a Cal value in the Devices/Files and it has a value of "1" (I think it's right).
    The database will store utilization from midnight. This works fine for charting, but is somewhat awkward when trying to compute utilization over multiple days since you need to pick up the last reading of the day for each day in the period of interest. I had to deal with this for the sprinkler controller.
    The data will be written to the virtual devices for Today's wattage and current wattage use rate.
    I can see just 1 km/h for Today's wattage and current wattage use rate. There must be something wrong.
    I did many test, including erasing the devices and messing manually with the ini file but no matter what I do it always show the same value (1 km/h).
    If you want the data at 1 minute intervals then you will need to run all your sensors at this rate. The only multirate sample provisions provided are for discretes. I do not provide any mechanism for scripting direct access to the DS9097U. Asychronous access is messy to manage. The general solution would be to associate a sample rate with each sensor, but I do not want to get into that development cycle at this time.
    This is what I do now. Running all sensors at 1 minute rate.
    For the moment it should be ok.
    You can develop database queries to subsample the data for various periods or to append data into different tables at different rates, but these fields will not be visible to mcsTemperature for charting.
    I guess I can define a discrete field and then put the data directly into so I can let mcsTemperature draw the charting.
    I'm leaving the testing up to you on this one. I confirmed the setup recognizes then new analog types, but I did not try to simulate a wattage sensor.
    There is something wrong I can't find but I think is the same as before.
    The only values I see appened to the database are 100 for the s8A000000052B521DG field (defined in [database] as ]35="s8A000000052B521DG,32,1") and 0 or 100 in the s8A000000052B521DW field (defined in [database] as ]34="s8A000000052B521DW,31,1")
    I'm attaching my ini file and the statud I see.
    The log looks fine with the counter reading correct:
    PHP Code:
    27/03/2005 19:14:05~!~mcsTemperature Debug~!~Wind Speed Counter=30594Prior Counter=30592Interval=11 seconds
    27
    /03/2005 19:14:05~!~mcsTemperature Debug~!~setIO ]34 from 0 to 19
    27
    /03/2005 19:14:05~!~mcsTemperature Debug~!~setDevice ]34 from 3 to 3
    27
    /03/2005 19:14:05~!~mcsTemperature~!~DS9x9x Port PortAddress=8A000000052B521D Family=DS2423 Counter=30594
    27
    /03/2005 19:14:16~!~mcsTemperature Debug~!~DS9x9x Port Device DS18B20 A7000000318E2828
    27
    /03/2005 19:14:16~!~mcsTemperature~!~DS9x9x Port PortAddress=A7000000318E2828 Family=DS18B20 Temperature=20,3125
    27
    /03/2005 19:14:17~!~mcsTemperature Debug~!~DS9x9x Port Device DS2423 8A000000052B521D
    27
    /03/2005 19:14:17~!~mcsTemperature Debug~!~Wind Speed Counter=30597Prior Counter=30594Interval=12 seconds
    27
    /03/2005 19:14:17~!~mcsTemperature Debug~!~setIO ]34 from 0 to 19
    27
    /03/2005 19:14:17~!~mcsTemperature Debug~!~setDevice ]34 from 3 to 3
    27
    /03/2005 19:14:17~!~mcsTemperature~!~DS9x9x Port PortAddress=8A000000052B521D Family=DS2423 Counter=30597
    27
    /03/2005 19:14:17~!~mcsTemperature Debug~!~setIO ]60 from 0 to 19
    27
    /03/2005 19:14:17~!~mcsTemperature Debug~!~Log Temperature Sensor Count=41INSERT INTO TemperatureNew3(SampleDate,CSVYear,CSVMonth,CSVDay,CSVHour,CSVMinute,CSVSecond,CSVWindSpeed,CSVWindGust,CSVWindDirection,CSVInsideHumidity,CSVOutsideHumidity,CSVInsideTemperature,CSVOutsideTemperature,CSVBarometer,CSVTotalRain,CSVDailyRain,CSVHourlyRain,CSVWeatherCondition,CSVChannel1Temperature,CSVChannel1Humidity,CSVChannel2Temperature,CSVChannel2Humidity,CSVChannel3Temperature,CSVChannel3Humidity,CSVEvapotranspiration,CSVUVIndex,CSVSolarRadiation,CSVWindChild,CSVIndorHeatIndex,CSVOutdoorHeatIndex,CSVDewPoint,CSVRainRate,CSVOutdoorTempRate,CSVIndoorTempRate,CSVBarometerRate,CSVChannel1TempRate,CSVChannel2TempRate,CSVChannel3TempRate,tA7000000318E2828,s8A000000052B521DW,s8A000000052B521DGSELECT #2005-03-27 19:14:17# AS QT,200500 AS Q0,300 AS Q1,2700 AS Q2,1900 AS Q3,1300 AS Q4,3600 AS Q5,1300 AS Q6,2100 AS Q7,2100 AS Q8,4200 AS Q9,4000 AS Q10,2000 AS Q11,1380 AS Q12,101104 AS Q13,3800 AS Q14,100 AS Q15,0 AS Q16,0 AS Q17,0 AS Q18,0 AS Q19,1990 AS Q20,3500 AS Q21,0 AS Q22,0 AS Q23,0 AS Q24,0 AS Q25,0 AS Q26,1280 AS Q27,2010 AS Q28,1380 AS Q29,40 AS Q30,0 AS Q31,-40 AS Q32,130 AS Q33,0 AS Q34,0 AS Q35,0 AS Q36,0 AS Q37,2030 AS Q38,0 AS Q39,100 AS Q40
    27/03/2005 19:14:27~!~mcsTemperature Debug~!~DS9x9x Port Device DS18B20 A7000000318E2828
    27
    /03/2005 19:14:28~!~mcsTemperature Debug~!~setIO ]1 from 0 to 19
    27
    /03/2005 19:14:28~!~mcsTemperature~!~DS9x9x Port PortAddress=A7000000318E2828 Family=DS18B20 Temperature=20,375
    27
    /03/2005 19:14:28~!~mcsTemperature Debug~!~DS9x9x Port Device DS2423 8A000000052B521D
    27
    /03/2005 19:14:28~!~mcsTemperature Debug~!~Wind Speed Counter=30600Prior Counter=30597Interval=11 seconds
    27
    /03/2005 19:14:28~!~mcsTemperature Debug~!~setIO ]34 from 0 to 19
    27
    /03/2005 19:14:28~!~mcsTemperature Debug~!~setDevice ]34 from 3 to 3
    27
    /03/2005 19:14:28~!~mcsTemperature Debug~!~setIO ]35 from 0 to 19
    27
    /03/2005 19:14:28~!~mcsTemperature Debug~!~setDevice ]35 from 3 to 3
    27
    /03/2005 19:14:28~!~mcsTemperature~!~DS9x9x Port PortAddress=8A000000052B521D Family=DS2423 Counter=30600
    27
    /03/2005 19:14:38~!~mcsTemperature Debug~!~DS9x9x Port Device DS18B20 A7000000318E2828
    27
    /03/2005 19:14:39~!~mcsTemperature~!~DS9x9x Port PortAddress=A7000000318E2828 Family=DS18B20 Temperature=20,375
    27
    /03/2005 19:14:39~!~mcsTemperature Debug~!~DS9x9x Port Device DS2423 8A000000052B521D
    27
    /03/2005 19:14:39~!~mcsTemperature Debug~!~Wind Speed Counter=30602Prior Counter=30600Interval=11 seconds
    27
    /03/2005 19:14:39~!~mcsTemperature Debug~!~setIO ]34 from 0 to 19
    27
    /03/2005 19:14:39~!~mcsTemperature Debug~!~setDevice ]34 from 3 to 3
    27
    /03/2005 19:14:39~!~mcsTemperature~!~DS9x9x Port PortAddress=8A000000052B521D Family=DS2423 Counter=30602
    27
    /03/2005 19:14:50~!~mcsTemperature Debug~!~DS9x9x Port Device DS18B20 A7000000318E2828
    27
    /03/2005 19:14:51~!~mcsTemperature~!~DS9x9x Port PortAddress=A7000000318E2828 Family=DS18B20 Temperature=20,375
    27
    /03/2005 19:14:51~!~mcsTemperature Debug~!~DS9x9x Port Device DS2423 8A000000052B521D
    27
    /03/2005 19:14:51~!~mcsTemperature Debug~!~Wind Speed Counter=30605Prior Counter=30602Interval=12 seconds
    27
    /03/2005 19:14:51~!~mcsTemperature Debug~!~setIO ]34 from 0 to 19
    27
    /03/2005 19:14:51~!~mcsTemperature Debug~!~setDevice ]34 from 3 to 3
    27
    /03/2005 19:14:51~!~mcsTemperature~!~DS9x9x Port PortAddress=8A000000052B521D Family=DS2423 Counter=30605
    27
    /03/2005 19:15:00~!~Event Trigger~!~Time Trigger (Apagar Luz PasilloA8 Off (Pasillo Luz Pasillo)
    27/03/2005 19:15:01~!~mcsTemperature Debug~!~DS9x9x Port Device DS18B20 A7000000318E2828
    27
    /03/2005 19:15:02~!~mcsTemperature~!~DS9x9x Port PortAddress=A7000000318E2828 Family=DS18B20 Temperature=20,375
    27
    /03/2005 19:15:02~!~mcsTemperature Debug~!~DS9x9x Port Device DS2423 8A000000052B521D
    27
    /03/2005 19:15:02~!~mcsTemperature Debug~!~Wind Speed Counter=30607Prior Counter=30605Interval=11 seconds
    27
    /03/2005 19:15:02~!~mcsTemperature Debug~!~setIO ]34 from 0 to 19
    27
    /03/2005 19:15:02~!~mcsTemperature Debug~!~setDevice ]34 from 3 to 3
    27
    /03/2005 19:15:02~!~mcsTemperature~!~DS9x9x Port PortAddress=8A000000052B521D Family=DS2423 Counter=30607
  • Michael McSharry
  • Mario from Spain
    Thank you very much, Michael.
    I'll try it tomorrow and will let you know how it performs.
  • Michael McSharry
    The data will be written to the virtual devices for Today's wattage and current wattage use rate. If you want the data at 1 minute intervals then you will need to run all your sensors at this rate. The only multirate sample provisions provided are for discretes. I do not provide any mechanism for scripting direct access to the DS9097U. Asychronous access is messy to manage. The general solution would be to associate a sample rate with each sensor, but I do not want to get into that development cycle at this time.
  • Mario from Spain
    After many hours working with mcsTemperature I can't manage to make it work
    I readed all the old threads about he 1-wire counters and tried everything, messing with the device type (number) in the Database section of the ini file (I tried 0,1,10,29,30) and the device type (character) in the Devices section.
    All I can get are some strange numbers showing in the status fields.
    I can see in the log mcsTemperature reading right the counter:
    25/03/2005 21:37:29~!~mcsTemperature Debug~!~DS9x9x Port <COM9>Device = DS2423 8A000000052B521D
    25/03/2005 21:37:29~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9> Address=8A000000052B521D Family=DS2423 Counter=23496
    25/03/2005 21:37:39~!~mcsTemperature Debug~!~DS9x9x Port <COM9>Device = DS18B20 A7000000318E2828
    25/03/2005 21:37:40~!~mcsTemperature Debug~!~setIO ]1 from 0 to 19
    25/03/2005 21:37:40~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9> Address=A7000000318E2828 Family=DS18B20 Temperature=23
    25/03/2005 21:37:40~!~mcsTemperature Debug~!~DS9x9x Port <COM9>Device = DS2423 8A000000052B521D
    25/03/2005 21:37:40~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9> Address=8A000000052B521D Family=DS2423 Counter=23498
    25/03/2005 21:37:51~!~mcsTemperature Debug~!~DS9x9x Port <COM9>Device = DS18B20 A7000000318E2828
    25/03/2005 21:37:51~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9> Address=A7000000318E2828 Family=DS18B20 Temperature=23
    25/03/2005 21:37:52~!~mcsTemperature Debug~!~DS9x9x Port <COM9>Device = DS2423 8A000000052B521D
    25/03/2005 21:37:52~!~mcsTemperature~!~DS9x9x Port <COM9>: Port=<COM9> Address=8A000000052B521D Family=DS2423 Counter=23501
    From time to time I get the counter devices without the Index number (I think after exiting setup):
    25/03/2005 21:34:52~!~mcsTemperature Sensor Info~!~A7000000318E2828, HS:]1, Index:97, DB:tA7000000318E2828,0,1
    25/03/2005 21:34:52~!~mcsTemperature Sensor Info~!~8A000000052B521DL, HS:]34, Index:, DB:s8A000000052B521DW,29,1
    25/03/2005 21:34:52~!~mcsTemperature Sensor Info~!~8A000000052B521DC, HS:]35, Index:, DB:s8A000000052B521DG,30,1
    I attach the ini file.
    Please, tell me if you want me to send you a small database with some data (anyway the s8A000000052B521DW has only 0s and the s8A000000052B521DG just 2085700's)
    Many thanks, Michael.
