Can't get mcsTemp up and running properly under HS2
  • Michael McSharry
    Different versions of HS2 react differently to plugin objects. If you look at \HTML\temperature.asp you will see three different techniques to deal with the different HS2 versions. I applied the same approach to forecast.asp in the attached. Change the name to .asp from .txt.
  • Guest's Avatar
    Guest started a topic Can't get mcsTemp up and running properly under HS2
    Hi Michael,
    I finally took the plunge and updated to HS2. Now I'm having a few issues getting mcsTemp (my favourite app and probably the only reason I keep coming back to HS), so I hope you can help me.
    I did a brand new install of Windows XP Pro and HS2 on top of that. I took the option to import the old config file and I moved the mcstemperature.ini file over from the old system.
    Now ... I was getting somewhere and I had forecast.asp running, but now after installing a few more plug ins and a bit more config I can only get :
    Script error: Object variable or With block variable not set. Response.Write hs.plugin("mcsTemperature").ForecastASP(request, response)
    Doesn't sound like I'm even getting past first base now.
    Any help gratefully received.
    Duncan
