Some problems with MCS Temperature plugin
  • mfisher
    I guess I should have mentioned that I'm using the WeatherXML script to grab weather data & MCSTemp is reading that xml file. I suspect that Weather.com is changing their data formats again but have not yet grabbed a "bad" xml file for proof.
  • jlikonen
    Hi Mark,
    I have also these errors at random times.
    Jari
  • mfisher
    I have been seeing this recently at random times as well.
  • jlikonen
    Hi Mike,
    I just noticed that I have an event running weathercom_xml.txt script every 120min. I am not quite sure whether this was originally included in your MCS Temp plugin or is it a separate script. If I am using the NWS site for forecast data do I need this weathercom script? I have to say that I'm somewhat confused now.
    Jari
  • jlikonen
    Hi Mike,
    In fact I am not quite sure how I get the forecast data. I enclose an image showing the setup for forecast. It looks like that I am getting the data from NWS and not from WeatherXML. Perhaps I should disable the WeatherXML or should I choose "Get from NWS site"? I enclose also the xml-file but it seems to be empty.
    Jari
  • Michael McSharry
    The offending line is below which lilkely means it cannot find the "ut" element in the node tree on the data from Weather.com. The current versions of mcsTemperature will not download from Weather.com, but it will process files downloaded via other means such as the WeatherXML script. The default xml file is at \data\weathercom_xml\weathercom.xml if you are reading it from a file. In this case you can post it to see if the format has changed.
    710 bMetricTemp = UCase(oNode.selectSingleNode("ut").text) = "C"
  • jlikonen
    started a topic Some problems with MCS Temperature plugin
    I have been getting following error messages in the HS log. Any ideas what is causing them?
    I'm using the latest plugin version.
    11 13:21:53 ~!~mcsTemperature~!~WeatherXML on line 710 Object variable or With block variable not set
    2.1.2011 13:22:54 ~!~mcsTemperature~!~WeatherXML on line 710 Object variable or With block variable not set
    2.1.2011 16:15:52 ~!~Error~!~Running script, script run or compile error in file: weathercom_xml.txt424:Object required: 'oNode' in line 120 More info: Object required: 'oNode'
    Jari
