Contacting HomeSeer This Week
See more
See less
MCS Temp--Error in SetDeviceLastChange
  • MCS Temp--Error in SetDeviceLastChange
    Hello, I upgraded to HSP 2.5.0.80 and now am getting the following error every time MCSTemp updates. I have attached my .ini
    6/10/2013 5:51:59 PM - Plug-In - Found plug-in: mcsTemperature, version: 6.4.0.0
    6/10/2013 5:54:06 PM - Warning - Setting device string, housecode is not set. String is: <table><td><img alt='Voltage' src='/images/sensors/voltage.gif' height='16' width='16'><img alt=' ' src='/images/sensors/blank3.gif'></td><td valign='middle' align='left'><font color='gray'>0 v</font></td></table>
    6/10/2013 5:54:06 PM - Error - In SetDeviceLastChange:Length of argument 'String' must be greater than zero.
    Sorry if I missed this somewhere.
    David
    DSteiNeuro
    HS3Pro
    MSI Cubi Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2201 Mhz, 2 Core(s), 4 Logical Processor(s) 16GB DDRl RAM
    Enabled Plug-Ins
    BLRussound, BLSpeech, HSTouch Server, JowiHue, MyQ, Nest, Rain8, Squeezebox, Ultra1Wire3, UltraGCIR3, Vista Alarm, X10,Z-Wave
  • #2
    Best change of understanding problem is with a general debug output. It seems to be indicating that some device that is selected has a blank house code or a full blank device code.
    • #3
      Here is the debug log. Nothing popped out at me.
      I tried deleting the .ini file and letting MCS Temp rebuild, but the error came back as soon as I started copying the virtual devices to HS. I also develted the HS devices and let MCS Temp rebulid these.
      I ended up rolling back to the prior version of HSPro, but would like to get this to work so that I can use the Aeon Multisensors which require the newer version of HSPro.
      Thanks if you can find anything.
      David
      DSteiNeuro
      HS3Pro
      Enabled Plug-Ins
      • #4
        The issue appears to be associated with reading the internal ADC from the Temp08 which likely does not show up as a devices when mcsTemperature asks the Temp08 for a list of devices at startup.
        It will be difficult to setup to try to get to the bottom of it, but I would like you to try the following. In your mcsTemperature.ini file you have the following.
        1B00000075179A26="$5,05:05,0,0,0"
        1B00000075179A26V="$51,05:01,0,0,0"
        INTERNAL_ADC__00V="$57,,0,0,0"
        1B00000075179A26A="%51,05:01,0,0,0"
        Change the internal ADC to be the following and then start HS2 up.
        INTERNAL_ADC__00V="$57,09,0,0,0"
        • #5
          I suspecyed this as well and tried several time to change the device code in the Sensor table with no luck.
          I will try editing the .ini as suggested.
          May be a while because I rolled back to the prior version of HSPro and everything is stable again. I saw the same error on other threads. I think that maybe Rich changed the error checking.
          DSteiNeuro
          HS3Pro
          Enabled Plug-Ins
