It gets the ExZero to work but I can't set any line colors. If I uncheck 'ExZero' then the colors I set are ignored and the lines come out black.
Don't bother playing with this any more. I went into my database and changed the house code for all my '+' house code devices to something else. Problem solved.
Graphs can't handle devices with "+" as 'house code'
Let me know if the attached works for you. Backup your current file as it has been a long time since this project was reopened.Attached Files
The + and - are used as special characters in the decode string for the setup so it is understandable. I believe I understand how to overcome it. I need to install HS2 to get setup for it again and then will post update for your evaluation.
I have some devices that have a "+' as the house code and when I try to set the 'ExZero' parameter to unchecked it messes up the graph colors. Any lines with ExZero unchecked end up black and with "1+1 as the color.Tags: None
