xapmcs1wire.exe stopped working
    Michael in early July all my xap 1 wire sensors stopped working. My xapmcs1wire.exe program is not responding. I cannot open its web page.
    I believe this is related to an automatic update of Windows 10 that occurred in early July.
    Is anyone else having this problem?
    Any suggestions?
    Steve Q
    xapmcs1Wire is a 32 bit application with underling drivers no longer supported. If a new OS is installed then likely it will no longer work. I run it on XP and never tried anything newer. It is actually running on a 1st gen Homeseer embedded XP computer.
      Thank you, Michael. I have not done much with my HS setup for the last year. It has been running without problems so I have not messed with it. So I spent some time reeducating myself about my setup. I am running HS3 on 2 computers. My primary computer is a Dell mini computer running windows 10. My secondary computer is a Dell Laptop running HS3 and my security camera software on Windows XP.
      My xap 1wire stuff was running on the XP computer. I was then passing the info back to HS3 running on Windows 10. Apparently a power failure caused my XP computer to loose much of my xAP setup info. I've got my 1 wire setup running again but I have to reconfig the devices in the mcsxap plugin on the XP computer.
      I think I have things under control. I'll let you know.
      Steve Q
        Michael, I was wrong, my secondary computer is running Windows 7 not XP. I am quite certain that it was running xapmcs1wire.exe and all was working fine with HS3 until earlier this month. Now, When I try to run xapmcs1wire I get the following message.
        Steve Q
