I'm getting very close to not only getting it working but also understanding the technology (which, having been in the technology business for 35+ years is something I seem to always try to do). But I have a few more questions.
First, I have three Hobby-boards.com modules: a temperature only, a temperature/humidity and a temperature/humidity/sunlight. For the moment, Ineamed the HS devices with the sensor type and the last 4 digits of the sensor serail number, so I know what Iam looking at. All three units are located within 3 or 4 inches of each other in an open area (i.e. I would expect the readongs to be the same.
So here are the questions:
1. First, the onle I understand: some of the measurements show up with two different names. I believe this is caused because the 1-wire xap program had seen them before I gave them a name and this is propogated through Homeseer. I believe that changing the 'accept' to 'reject' and/or excluding them in the 1-wire setup will solve this.
2. I get five temperatures: one from the DS18S20 in each of the three mdules and one from the DS2438 in the temp/hum and temp/hum/light modules. Would you expect the temperatures to be so varied? I thought they were speced as 0.5 degrees C, yet I see a variance of over 4 deg F (or 2+ deg C). If I eliminate the one I've called 'Temp-5010' which is the temp only unit and it is the only one not in the Hobby-Boards plastic case, perhaps based on heat generated by (maybe) the voltage regulator. That would not be a good thing in my mind. Perhaps I'll take them out of their cases and/or remove the jumper so everything runs on parasitic power and see what that does.
3. I was trying to figure out the relationship between the three voltages Michael's program reports and the DS2438 hardware. I think I've got it but perhaps, Michael, you could confirm: V0 is the voltage register with the A/D configured to convert VDD; V1 is the voltage register with the A/D configured to convert VAD (which comes from the humidity chip); V2 is the current sense register, which is really the voltage across the resister in series with the sola diode. Also, it appears that the 'sunlight' number reported is V2 times 400; and the relativve humidity reported is somehow inversely proprtional to V1. Not sure why I care except in my attempt to figure out the next one.
4. One of the humidity sensors is reporting a constant humidity of 100% (and V1 is a very low number of .09). The other correclty reports 47% (my Davis Vantage currently says 45%, so this is well within the expected error range for both) and V1 is 2.21. I am assuming that the one reporting 100% is defective and I should probably send it back to Hobby-boards for a replacement. Is there any other possible explanation?
5. Some of these have never been sent to Homeseer. Is that because they are only sent on change, so if Homeseer wasn't configured to accept them when it started and they never change (like the 100% humidity), they are never updated?
6. Finally, is there a unit available that is better packaged for wall installation than the hobby-boards units? Specifically, it would be nice if the RJ45's came out the back so the cables could go into the wall without being visible.
Thanks for any help or advice!
Pete
Pete
