I have a simple test event as per pic1 attached. I have another event as per pic2.
I would expect this event to fire if I switch output 8 on from the devices screen. It doesn't.
I would also expect this event to fire if I run the 2nd event. It doesn't.
Even if I use another trigger such as Device value has changed and becomes, the event still doesn't fire.
If I switch the output on from HS2, then the device is updated in HS3, and the event DOES fire.
Switching the device on via the devices screen results in the following log message.
May-17 21:33:16 Device Control Device: test phaedrus.netiom.Location3:Output.8 to On (100) by/from: CAPI Control Handler
Also, I am getting this message in the log every minute.
HSEvent Line 0 Arithmetic operation resulted in an overflow.
Am I doing anything wrong? I am using v39 of the plugin.
