Invert Digital output
  • Invert Digital output
    Is there a way to invert the output so it is always high (or 5)?
    Every time the plugin disconnects the output goes low (0), and I need to have an event to turn it high after a reconnect. The opto isolated relays I use fire on low.
    I don't think there is a way to configure the ADIO-100 output to be inverted, but you can get relays that are active high. The relays I use for Arduino are configurable to accept active high or active low. If you need to you can change the ADIO-100 HS device values for on and off to make it work with a different relay.
    Randy Prade
    Aurora, CO
    Prades.net
      [ATTACH]64137[/ATTACH]
      Thank You, That is what I need.
