I have a nuisance with my ADIO 100 turning on lights associated with multiple bits. I have step pressure sensors that turn on lights for one set of stairs attached to bits 0 and 2 (top and bottom sensors). A different step pressure sensor for a different set of stairs is attached to bit 1. All three share a common ground attached to the ADIO.
The problem is that no matter what set of stairs are stepped on, the light to the other stairs comes on at the same time. My guess is that the common ground is the culprit. I have tried putting a 1k resistor at each bit terminal to no avail.
Any ideas would be appreciated. Thanks.
