ADIO100-IP2SL Ethernet to Serial Converter
  • #16
    ADIO100 - ITACH IP2SL
    Uhaoooo,
    After some days of work I can see the solution of my problem. I hope that post can be useful to all those who use ADIO100 with IPSL2.
    The problem was the bad position of DIP Switch inside Adio100 and the configuration of the COM port on the PC. I put the DIP switch in "ON" position (115200 baud rate) and the same thing in the configuration of the virtual port through the software "Virtual serial port emulator" (set 115200 baud rate) where I used the port 4999. Then in the configuration of the IPSL2, that it is possible to open after have found its IP using the software "iHelp" (Global cache), set the baud rate in the same way (set 115200 baud rate) .
    Thahks at the your indications, Thahks Thahks
    Massimo
    • #17
      HomeSeer Version: HS3 Pro Edition 3.0.0.318
      Operating System: Microsoft Windows 7 Professional - Work Station
      Number of Devices: 383Number of Events: 209Available Threads: 200
      Enabled Plug-Ins
      3.0.0.29: ADIO-100
      1.0.0.131: Arduino Plugin
      2.0.3.0: BLDatabase
      3.0.14.0: BLMediaPlayer
      2.0.5.0: BLVolume
      0.0.0.42: Current Cost 3P
      0.0.0.3: Device Comparison 3P
      1.1.2.0: Device History
      3.0.0.32: EasyTrigger
      3.0.0.75: HSTouch Server
      3.0.0.14: NetCAM
      3.0.1.90: PHLocation
      1.0.0.5: Restart
      3.0.0.21: VWS
      3.0.1.130: Z-Wave
