Is there any way to get this Ethernet relay board to work with homeseer?
  • Is there any way to get this Ethernet relay board to work with homeseer?
    I found this ethernet relay/analog/digital input output relay board. it looks much more modern in its design than the ADIO. I want to install it in a different location from my Homeseer and alarm panel. Ethernet would be much easier.
    http://denkovi.com/ethernet-io-relay...-web-12-relays
    John
    As they advertise they have .net software to download for it that would/should make it easier to get going with HS as if you could rip out the important bits and use it with HS. Ideally though you could do with writing a HS plugin for it to deal with the board polling for adc/inputs, I don't know what you would be able to do with SNMP though, if you search for SNMP someone appears to have got a similar board from that company working a albeit just for the outputs (which is always easier).
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
