Careful with your ADIO
  • Careful with your ADIO
    I ended up blowing my outputs up on my ADIO when hooking up a relay board. Stupid me.
    I opened it up and saw there is no protection from the PIC microprocessor inside, so you don't get any second chances of a slip up.
    I reached out to HS support to buy a new PIC or have them repair it outside of warranty (pay for the services). They said all they can do is sell me a new entire unit. So mind your ADIO out there! I wouldn't buy one again BTW.
    Anyone know how to delete the plugin for it?
    -Tim
    HSPro - 3.XXX - Dell mini W7 x32
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
    HAI RC2000 Thermostat
    What are you looking to switch to? Just curious, thanks!
      I'm going to try the arduino plugin. Those boards are a lot cheaper and you have to add relay boards anyway, so why not.
      -Tim
      Way2 Call
      Elk M1 Gold
      UPB HAI switches
        Thanks for the reply. Besides there's an error in the log every time my ADIO input triggers, it seems HS3 plugin has a lag with reading inputs that I didn't have on HS2. When using it to trigger an image from a CCTV camera, a lag means the difference of seeing and not seeing what passed by the camera Looking for something with less lag.
          FYI been playing this weekend with an Arduino Yun with MQTT. Wrote a simple sketch using the Adafruit Yun MQTT example where I can trigger inputs and publish them to an MQTT server I have running locally. The HS3 MQTT plugin can pick it up and it's virtual instantaneous.
            The schematics and other documentation here may be of some value
            http://www.integrityusa.com/rs232-m1...a-acquisition/
            Best Regards
