status graphics end value
  • status graphics end value
    Evetime I restart homeseer the one wire status graphics end defaults back to 150 is there a way to leave it at the set point which I have set to 270 degrees also can you invert the alive output pin?
    What version of the plugin are you running? This is because of the devices being upgraded on startup. I can fix this in a future build.
    The alive pin can not be inverted in the plugin but if you know what you are doing then it can be changed in the sketch.
    Greig
    Scripts =
    Various
      ver. 1.0.0.131 Thanks
        I will add this to the to do list.
        Greig.
        Scripts =
        Various
          This should be fixed in the latest Beta build in the updater.
          Greig.
          Scripts =
          Various
            does the update fix the decimal for temperateure sensor ?
            everytime i restart HS3 , the decimal get reset to 1 , but i need it set to 2 to have 0.06 precision on temperature
            i dont have time to get all my board out and upgrade them right now so better asking before
            thanks
