Error in Logs / Halts HS Processing
  • Error in Logs / Halts HS Processing
    I am seeing this error randomly from time to time, and when it happens, everything for HS grinds to a halt until i do a complete restart of HS. I only have just a couple things setup right now on my Pins, and when things are restarted, all works as expected. Seems roughly about 24 hours in I am seeing this after a restart. What should I be looking for? I am on the latest version as I just installed this PI about 1 week ago.
    Take that back, this time it completely corrupted HS in some weird way and I am currently reverting back to one of my nightly backups... when I tried restarting HS, it stated something along the lines of can't start API because invalid port....
      can you send me a debug log?
      Do you have the MQTT plugin installed?
      Greig.
      Scripts =
      Various
        I have seen this before and a system restart fixed it.
        Greig.
        Scripts =
        Various
          I don't have MQTT installed. I will start up debug logs and wait for it to happen again. I did end up having to restore from my nightly backup to get HS to come back online.
          I will reach out to you once i have more logs.
            Can I just check what version you are running?
            Grieig.
            Scripts =
            Various
              1.0.0.36 is the version I have installed
                OK This may be an old problem as I had to fix this in the past. I am going to move the beta up to be the production build some time next week but I would suggest you install the V1.0.0.132 from the beta section in the updater as this is a stable version with lots of extra features.
                Greig.
                Scripts =
                Various
                  Just to follow up on this. I updated to the latest beta as you suggested and the unit has been solid since, also fixed my debounce issue I was having.
                  Thanks for the help on this.
