API SendToHS problem
  • API SendToHS problem
    Hi
    I'm playing with the API version of the sketch.
    While it seems FromHS works fine, it seems I'm doing something wrong with SendToHS.
    I've created a simple circuit with one button and a LED.
    RX from HS is tested reading a variable and if true, printing to Serial.
    TX to HS is tested sending to HS the status of the LED (1/0).
    While this value is correctly printed on the Serial, HS instead always shows 0
    (Board 2, Device Ref = 149, API Input 1, Value = 0)
    I'm using Available Sketch Version = 1.0.0.127, API Version = API1.0.0.118
    and IDE 1.6.8 for MacOSX
    Any idea what I am doing wrong?
    /*Execute regardless of connection status*/
    if (alert=FromHS[0]){    //test RX from HS
    Serial.println("ALERT");
      val = digitalRead(BUTTON);  // read button
      // check if something has changed
      if ((val == HIGH) && (old_val == LOW)){
        status = 1 - status;
      old_val = val;            // update old_val
      if (status == 1) {
       digitalWrite(LED, HIGH);   //  led ON
      else {
        digitalWrite(LED, LOW);    // led OFF
    Serial.println(status);
    SendToHS(1,status);
    My first guess is that this is sending to homeseer on every loop of code and is flooding the serial port with data.
    Try this.
    PHP Code:
    val digitalRead(BUTTON);  // read button
    status status;
    old_val val;            // update old_val
    if (status == 1) {
    digitalWrite(LEDHIGH);   //  led ON
      else {
    digitalWrite(LEDLOW);    // led OFF
    SendToHS(1,status);
    Scripts =
    Various
