Can't Donwload new sketch file
  • Can't Donwload new sketch file
    Error Creating Homeseer.ino = (Error finding line = #define BoardType)
    Available Sketch Version = 1.0.0.36, API Version = Error Finding API.ino
    Did you remove the API.ino file from the Homeseer configuration folder? A simple fix is to download the plugin again to replace the missing files.
    What plugin version are you running and have you just upgraded?
    What OS are you using?
    Sent from my SM-G925F using Tapatalk
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      when I install from the updater. then it remove all *.ino files from homeseer
      how can I download it again without removing the plugin and lose the setup.
      I use windows 10
        What version are you installing an is there any errors in the log on install?
        You can just look for the plugin in the updater and check the box to download the same version and update the files.
        Greig
        Scripts =
        Various
          I fix the problem with downloading the sketch but
          I get this error when I try to upload the sketch
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:19:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          char* Version = "1.0.0.127";
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino: In function 'void InputCheck()':
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:133:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" I ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:135:15: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino: At global scope:
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:148:29: warning: narrowing conversion of '-1' from 'int' to 'byte {aka unsigned char}' inside { } [-Wnarrowing]
          byte OutPinArray[40] = { -1 };
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:151:43: warning: narrowing conversion of '-1' from 'int' to 'long unsigned int' inside { } [-Wnarrowing]
          unsigned long previousOutMillis[40] = { -1};
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino: In function 'void AnalogueCheck()':
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:209:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" A ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:211:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino: In function 'void OneWireCheck()':
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:277:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" Rom ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:280:50: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          if (tempDeviceAddress[i] < 16) Send("0");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:283:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino: In function 'void DataEvent()':
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:512:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" I ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:514:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:523:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send("Version ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:525:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:527:20: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send(" HS3");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:530:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send("Connected ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:686:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send("Alive ");
          D:\David\Downloads\HomeseerBoard2\HomeseerBoard2.ino:712:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
          Send("Reseting ");
            This is nothing to worry about it is just a warning and it should all work fine. Check you using the correct Arduino IDE for the version of the plugin you are using. This is listed under the plugin configuration page.
            Greig.
            Scripts =
            Various
              Thx for the help.
              I get the sketch to the board but will not connect
              I already two board connected to my hs3 and this 3 board will not connect have try to ping it and no respot
              have looked into you guides. but no help
              Also board 2 say Version Mismatch I get I must update the sketch.
              Greig.
                Originally posted by Daarn View Post
                Thx for the help.
                Yes with a version Mismatch you must update the board with a new sketch.
                Send me the Board sketch and a debug log and I can look at why the board will not connect.
                Greig.
                Scripts =
                Various
                  Here are the files
                  Greig.
                    THX
                    for the help it was not the plugin or sketch that didnt work something was wrong with the switch I use
                    Are that easy to invert status on=1 and off=0 to on=0 and off=1?
                      THX
                      With an input you would just set up the status value to be what you want.
                      With an output there is an invert function that is under the Arduino tab on the output device configuration page.
                      Greig.
                      Scripts =
                      Various
