HSTouch - status tracking - board status
  • HSTouch - status tracking - board status
    Hi
    i found a bug with the plugin , or maybe with Hstouch , i honnestly dont know
    When i add a Text box with tracking using "status text" to track the state of a board ( connected , disconnected , reset , error)
    The result is an empty text box
    This is the only device in HStouch that have no text value available
    Can you tell me if it can be fixed?
    I think it can be related to the fact that there is two lines for 0 , 1 and 4 in the Status Graphics tab on the configuration page of the device ( just a guess)
    Thank you
    I have no idea why it will not show and i put it down to a HSTouch Quirk!
    I would suggest adding the device and setting status tracking to use value and then set up Alt text for the values in HSTouch and this will give you the same results.
    Greig.
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      nice workaround indeed .
        Good one Greig.
        I had this issue ages ago and never bothered following it up...Thanks for the workaround
        HS 2.2.0.11
