Just getting started with adding sensors to my Arduino. I'm using ver 1.0.0.139 of the plugin.
I've gotten two boards (nodeMCU 12E) loaded and I see them in the device listing. Plugin says they are both communicating.
I've been working for a few days on a breadboard with a group of sensors. I am trying to build some multi-sensor nodes to be placed in several different locations. The sensors are motion, DS18B20, door/window, and carbon monoxide sensor. I've got a simple test program that talks to each of them properly. So now I want to integrate the sensors into the plugin sketch.
I thought the temp sensor would be pretty easy. In my test program it operates as a OneWire device. I see in the documentation it says if you want to add a DS18B20, select the OneWire type of pin. Problem is, I see no reference to OneWire on my board configuration screen. I see Input, Output, Alive, and LCD. What I don't see are PWM or OneWire.
Ideas?
Ideas?
