1 wire support
  • 1 wire support
    Is one wire support still only the three temp sensors listed in the help fil;e or have other5s bbeen added?>?
    yes it is just the temp sensors. Why what are you looking at using?
    Greig.
    Scripts =
    Various
      Im not to sure Greig, Humidity,Voltage,Current,Switch,Co0unter are just some ideas.
        Are you suggesting that all of those sensors fit into the OneWire category? There are digital and analog versions but in my mind, few one wires other than the temp/humidity sensors (Dallas). If you are on a UNO or equivalent, you should be covered as far as pins go. And I thought OneWire worked there too. Are you on an ESP? I am - nodeMCU. Digging the wifi. Wishing for OneWire (temp) and A0 (air) or maybe the API version (haven't explored that).
          The NodeMCU API Mode is now available in V1.0.0.140(Betta)
          Greig.
          Scripts =
          Various
