I have several nodeMCUs with on-board wifi that I am using with the plugin. They connect to my wireless network just fine. However, when I look at all the networks available, each of the nodeMCUs have created a network. Is this normal? Seems like a potential security risk.
nodeMCUs creating their own networks
I am running the standard sketchs for the plugin. In the sketch it has the SSID and PSWD of my wifi network. I expected they would act like any device and just connect, which they appear to do, but I wasn't expecting them to show up in my available networks on my laptop or phone. The server that HS3 and the plugin run on doesn't have wifi. Each node has created a network with a nodeMCU name. I guess anyone close enough would see them. That's where my security concerns originate. Truthfully, I am very rural and it is unlikely that anyone not standing on my property could ever see them as available wifi networks. If I knew more about how secure they might be, I could live with it.
Originally posted by logbuilder View PostI am running the standard sketchs for the plugin. In the sketch it has the SSID and PSWD of my wifi network. I expected they would act like any device and just connect, which they appear to do, but I wasn't expecting them to show up in my available networks on my laptop or phone. The server that HS3 and the plugin run on doesn't have wifi. Each node has created a network with a nodeMCU name. I guess anyone close enough would see them. That's where my security concerns originate. Truthfully, I am very rural and it is unlikely that anyone not standing on my property could ever see them as available wifi networks. If I knew more about how secure they might be, I could live with it.HS 2.2.0.11
Hi All, I noticed the same issue with my NodeMCU's, there is no need to have them broadcasting their SSID during normal client operation, you can set them to station mode adding the following to your code:
WiFi.mode(WIFI_STA);
Be great if the plugin could be updated to include this as an option in the generated .ino's.
Mike
Regarding setting WiFi.mode(WIFI_STA);, this seemed like good placement to me. Seems to be working however more testing needed. Feedback appreciated.
Code:#if BoardType == 3 //Serial.begin(115200); WiFi.begin(ssid, pass); WiFi.config(ip, gateway, subnet); WiFi.mode(WIFI_STA); /* <- newly added line */ while (WiFi.status() != WL_CONNECTED) { delay(500); }
