It could be the refreshing of LCD data. I use an input and output on every board for testing purposes. I connect an output pin to an input pin. Then I turn the output on with an Event. A second Event looks for the input to change. If the input doesn’t go high with the output other events will send a message or perform a reset depending on a counter that is incremented each time the test fails. This cycle is repeated every 3 minutes for each board. I do not use any other inputs or outputs on the NodeMCU.
Just for data, I’ll setup a test NodeMCU with only inputs and outputs and see what happens. The three NodeMCU boards I removed from the system were using outputs controlling three relays each, in addition to the test input and output.
