Long delays, how is your setup ?
  • #16
    Thanks Greig, I will go for both: Separate board AND change timing.
    What would be great would be to also have this board transmit what comes to an ASCII pin, back to HS.
    This would help a lot to get rid of the COM transmitting over wires for my electrical counter, witch is in the same closet.
    Thanks a lot for all this help, the plugin is very easy to handle, adding test boards ans pins in a pinch is a very nice feature
    • #17
      You could build this with the plugin on a board using the API mode and your own code to get the ASCII data on to the board and in to Homeseer.
      Greig.
      Scripts =
      Various
      • #18
        I was really hoping not to have to use my own code, since I am not good at this.
        I might try when things get more calm on the arduino plugin front ...
