Degree symbol on LCD
  • Degree symbol on LCD
    I have a couple of 1-wire temp sensors hooked up to various arduinos,
    The suffix for the sensors is configured for and in HSTouch this is displayed correctly.
    However when I send Kantoor : $$DSR:452: to the LCD display the difference in character set used causes it to show ?C instead of C
    Anybody if the display character set has a degree symbol? Tried a variety of characters but no luck.
    According to http://www.lcd-module.de/eng/pdf/doma/dip204-4e.pdf the ASCII value should be 128 but it translates into ?
    I have not yet found a way to show this on the LCD.
    Greig,
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      and should display as on the LCD if the Arduino code is not changing the codes it is sending to the LCD...
      Best regards,
      -Mark-
          Best regards,
          -Mark-
            No problem easily overlooked in the overload of information .....
            Out of curiosity, have you tried all of the character values from 128 - 255? If they all display as ? then I would assume that the Arduino LCD driver code does not accept character codes over 127. Are there other LCD drivers that can be used?
            Your thoughts align with what I am suspecting but there might be something else too. It could be the LCD driver simply not processing the high ASCII values in the right way but it could also be the I2C interface driver or the Arduino plugin itself.
            I have tried several other characters but they all generate question marks.
            The whole setup depends on three important criteria:
            1. Does it support the LCD display
            2. Does it support the I2C interface
            3. Does the Arduino plugin support it
            Would love to hear if someone has played with different drivers or did some reverse engineering
