I don't see the COM property on my pluging setup page
  • #16
    Originally posted by langenet View Post
    Will do... Interestingly enough, I can ping the IP address while the USB is connected. However, when I disconnect it stops. The plugin never connects however to the board and my router doesn't see the device on the network either. So something wonky and perhaps a side affect using the USB.
    Robert
    What power supply are you using when on the network? you can use the usb for power or a 7 - 12v psu.
    Greig,
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
    • #17
      Well... that's embarrassing . I did have a small 5 volt power adapter connected thinking that 5vdc was fine since it only took 5 vdc from the USB. Anyway, don't know why I didn't try another adapter and/or verified input voltage range, but I've got 12 vdc going in now and it connected.
      Thanks again.
      Robert
      • #18
        Good news. Have fun.
        Sent from my SM-G925F using Tapatalk
        Scripts =
        Various
        • #19
          Well I wish it lasted but to no avail. So after running the LCD overnight without issue, I added 2 input , pins pin2 and pin3 then the connection problem came back. It appears to be very sensitive to changes made when adding input or output pins. In any case, I turned on logging and was distracted for a couple of hours so you have a good sample to view.
          Attached is the log.
          Robert
          • #20
            Any idea on what's going on? I have your plugin as trial and would really like to use it. It will not ever connect without having Auto Connect enabled. Even then, it only maintains the connection for a short while, then fails.
            Below is when I press connect only. Device responds to ping immediately - <1 ms.
            Jun-02 9:27:50 AM Arduino Plugin Disconnected from Board No:1 at ip address 192.168.1.61 Port No:8900
            Jun-02 9:27:50 AM Arduino Plugin Error = Board: 1 Connection FAILED.
            Jun-02 9:27:35 AM Arduino Plugin Warning = Board: 1 has a connection ERROR. Retrying.
            Jun-02 9:27:20 AM Arduino Plugin Warning = Board: 1 has a connection ERROR. Retrying.
            Jun-02 9:26:20 AM test Connect button pressed
            Jun-02 9:26:20 AM Arduino Plugin Connecting Board No:1 at ip address 192.168.1.61 Port No:8900
            Robert
            • #21
              please send me the sketch you are running on the board to look at it and confirm your setup.
              Greig.
              Scripts =
              Various
              • #22
                So I removed the plugin from my system including renaming the Arduino Config directory. Installed .142 and setup an Arduino Mega 2560 board using the same network shield and have a rock solid connection. I kinda doubt it was my Uno but rather a messy sketch. In any case, it's time to let the fun begin.
                Thanks for all your help!
                Robert
