Hello, I have a Hometroller Zee S2, I installed the plugin when I added a new board no COM settings are showing, I have it connected to one of the USB ports of the Hometroller. Is there anything special I have to do on the Hometroller?
I don't see the COM property on my pluging setup page
You can not use USB on the Linux based systems it will only work with a Ethernet connection.
Greig.
Sent from my SM-G925F using TapatalkZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Sorry but this is not something I plan on adding to the plugin.
Scripts = Various
So now I'm even more confused... I'm just starting to get into this and so I have an Arduino and a network shield on my network. However, don't you need to load a sketch with the appropriate network code to handle the network comm? I don't have it working yet on the network but was thinking this was the only way to get it to go.. Setting up the IP through the UI doesn't do anything here.
I was also reading in the forum that the network connection is somewhat unreliable - perhaps it was during the earlier releases... can you comment on this? I need a reliable network connection and if this is problematic, perhaps networked USB controller may be the way to go??
RobertLast edited by langenet; May 23, 2017, 08:20 AM.HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by langenet View PostSo now I'm even more confused... I'm just starting to get into this and so I have an Arduino and a network shield on my network. However, don't you need to load a sketch with the appropriate network code to handle the network comm? I don't have it working yet on the network but was thinking this was the only way to get it to go.. Setting up the IP through the UI doesn't do anything here.
Robert
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Thanks Greig I thought that the sketch needed to get loaded.
Unfortunately, after loading both API and non-API sketches following your instructions - no love.
I am running IDE 1.6.8 and noticed a bunch of deprecated warnings as well...
C:\Users\Robert\Desktop\HomeSeer\My-Arduino-1.6.8-windows\arduino-1.6.8\HomeseerBoard1\HomeseerBoard1.ino:19:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* Version = "1.0.0.127";
C:\Users\Robert\Desktop\HomeSeer\My-Arduino-1.6.8-windows\arduino-1.6.8\HomeseerBoard1\HomeseerBoard1.ino: In function 'void InputCheck()':
C:\Users\Robert\Desktop\HomeSeer\My-Arduino-1.6.8-windows\arduino-1.6.8\HomeseerBoard1\HomeseerBoard1.ino:133:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Send(" I ");
C:\Users\Robert\Desktop\HomeSeer\My-Arduino-1.6.8-windows\arduino-1.6.8\HomeseerBoard1\HomeseerBoard1.ino:135:15: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Send(" ");
^HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
This is all warnings not errors and they are nothing to wory about. If you load the normal sketch can you ping the board on your network?
Scripts = Various
No I cannot ping the device. One thing I'm confused on is whether or not to select Ethernet shield v2. Though, I tried both, I don't know what constitutes a v2 network shield. Mine is a 5100 compatible shield.
Secondly, can you just pick any old MAC address? I thought this a hardware physical address as defined in the network interface. Hum... I better take a look to see if it's marked on the card.
RobertHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by enigmatheatre View PostThis is all warnings not errors and they are nothing to wory about. If you load the normal sketch can you ping the board on your network?
Greig.
I've included the log. Perhaps there's something obvious....
RobertAttached FilesHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by langenet View PostI tried again this evening but still can't get it to work using the normal sketch.
Robert
Scripts = Various
Will do... Interestingly enough, I can ping the IP address while the USB is connected. However, when I disconnect it stops. The plugin never connects however to the board and my router doesn't see the device on the network either. So something wonky and perhaps a side affect using the USB.
