Important info for nodeMCU users
  • Important info for nodeMCU users
    The nodeMCU is a really good platform for wifi based arduino. It works well with the HS3 Arduino plugin.
    There is something about the nodeMCU that caused me great problems when I was first starting to use it. Since others are starting to express interest in this chip, I thought I should post so that others don't suffer as I did.
    The nature of the problem is that the pin numbers on the physical nodeMCU board do not directly correspond to how you need to reference them in the IDE sketch. When I first started with Arduino, I got an UNO for learning. I highly recommend that everyone just starting out get a vanilla Arduino UNO. I did a few sketches testing some sensors and got them working. Felt pretty good. Then I tried porting them to the nodeMCU. None of the sensors worked. Long story short, with an UNO, if you plug into pin 2 you reference it by 2 in the sketch. With a nodeMCU, if the sketch uses pin 2, you need to plug into pin D4.
    Here is a pic of the cross reference and also a link to an article discussing this. Saved me a bunch of headache once I discovered this.
    Link to article:
    http://henrysbench.capnfatz.com/henr...-input-basics/
    Pic:
    Great information! Thanks for letting us know.
    Robert
      Thank you very much for posting it, it will definitely help me a lot and I'm sure others as well.
      Sent from my SM-G935V using Tapatalk
        Also another little trick to watch for is that I have some of the 0.9 NodeMCU versions, I was powering them directly from the 5V pin (rather than use the micro USB) and couldn't figure out why they were misbehaving whereas would work fine on USB power when removed from the board. Turns out there is some cleverness going on with the GPIO lines when powered from USB to automatically handle them so it boots from flash rather than go into it's programming state. Perhaps not the same for every version but sure gave me a headache for a while trying to figure it out.
        My Plugins:
        Yeelight 3P | Nanoleaf 3P
          Here is another diagram about ESP 8266 nodeMCU pins. There is more info and I'm sure it is important but to be honest I'm not clear about it all.
            logbuilder,
            Could you point me to a good version of the nodeMCU board that you are using. I am just getting starting playing with arduino and order some kits. However, I thought I had ordered wifi and didn't. I may still start with this for some learning, but want a board that has wifi onboard. Is this the one that you are using. I can learn more on my own, but just want to order the correct stuff to play with and it's a bit overwhelming the number of boards and separate wifi modules out there.
            https://www.amazon.com/HiLetgo-Inter...iletgo+esp8266
            Thanks.
            - Tom
            HSPro/Insteon
            Web Site
            YouTube Channel
              Tom, I have ordered those exact NodeMCU units from Amazon and they work very well.These units have WiFi on them and have been very reliable in my setup.
              I have one of the units on top of my gas water heater, it monitors temperature from the area, hot and cold water lines as well as the intake and exhaust for gas area.
              Good luck.
              Billy Draper
                I have 5 of those boards from Amazon and all work perfectly.
                John
                  Thanks, Billy and John. I ended up ordering a different one,
                  the ESP32. I'm guessing this one will work fine too and if I ordered it right away, I'd be able to get it tomorrow to experiment.
                  Good luck.
                  - Tom
                  HSPro/Insteon
                  Web Site
                  YouTube Channel
                    I ended up buying some ESP-12E boards, they are good and easy to setup as they have the USB socket onboard. I've been playing with these using the Arduino Plugin and the MQTT plugin, they arent too bad.
                    Anyway all good experimentation....
                    Pete
                    HS 2.2.0.11
                      Just seeing this thread had me pull out my new nodeMCU and wonder how do I setup the WSID/password to wifi use??
                        If you are using this plug-in, they are set up on the config page. You will be offered a spot for SSID and password when you select this board type. The plug-in will generate a sketch containing both.
                        Randy Prade
                        Aurora, CO
                        Prades.net
                          Link to article:
                          It is important to note that if you are using the standard sketch (not the API), the pin numbers on the configuration page correspond to the pin numbers one the NodeMCU board. If you want to use "D1" as an output, you configure it as "D1" on the configuration page. If you are using the API, then you need to specify the GPIO pin numbers as shown in the above linked article.
                          Randy Prade
                          Aurora, CO
                          Prades.net
                            [ATTACH]65469[/ATTACH]
                            How do I find this option through my plug-in? I installed today, but I just have Arduino and Arduino API to choose from, no option of NodeMCU.
                            Am I missing something?
                              What version of the plug-in are you running? You may need to install the beta plug-in.
                              Randy Prade
                              Aurora, CO
                              Prades.net
