Skipping Events
  • Skipping Events
    Hi All, I have a problem that has come up recently , Some times when HS3 runs events it seems that the I/O box does not always carry out the change of out puts on the arduino board.
    Inputs seem to be fine. Just outputs.
    The board is connected via USB directly to the HS3 box.
    I mostly happens when the system is running a lot of events at once. Like when the house is going into away mode and its locking doors turning off lights and setting the alarm.
    I have 15 inputs used and 16 outputs used.
    More often then not inputs are changing at the same time as outputs.
    HS3 is running the event, But I/O has not changed.
    Is this a USB connection problem , Should i connect via Ethernet.
    Vaughan
    I think I had some issues with USB that were similar with relays not turning on....I remember turning 16 relays on and off in succession soak testing and some were missed....why I never found out.
    I went Ethernet instead, works 100%...
    Cheers..Pete
    HS 2.2.0.11
      USB
      Ok Thanks Pete, I will convert it to Ethernet and give it a go.
