Two NodeMCU, one disconnects the other
  • Two NodeMCU, one disconnects the other
    I have two NodeMCU, one using the normal NodeMcu and an analog sensor, the other is identical to the above but I try to use the NodeMCU API (Code below) When I connect the one with API, it disconnects the normal NodeMcu, any reason why?
    //**************Declare your variables here*******************
    int sensorPin  = 4;     //  ESP 12E pin D2
    int sensorValue = 0;  // variable to store the value coming from the sensor
    void HSSetup() {
      //Add YOUR SETUP HERE;
    pinMode(sensorPin, INPUT);
    void HSloop() {
        //Add YOUR CODE HERE;
        /*Execute regardless of connection status*/
     if (IsConnected == true) {
       /*Execute ONLY when HomeSeer is connected*/
       // read the input on analog pin 4:
       // analog reading (which goes from 0 - 1023)
        sensorValue = analogRead(sensorPin);
        SendToHS(1,sensorValue);
     }    // end of 'if (IsConnected == true) {'
    The problem is your API code. You are sending the value on every loop of the code so this will be flooding the plugin with data. You need to add code that checks if the Analog pin has changed value and if so send it to homeseer.
    something like this is fine for a analog device that is not changing value to often but if you have a device that is always changing then it is best to add a timer to send the data every x seconds.
    void HSSetup() {
    void HSloop() {
      if (analogRead(sensorPin) <> sensorValue){
    Greig.
    Scripts =
    Various
      Thanks Greig for all your help,
      Aldo
        I'm getting this message, Arduino: 1.8.1 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
        E:\Aldo\Downloads\APIBoard4\APIBoard4.ino: In function 'void HSloop()':
        APIBoard4:38: error: expected primary-expression before '>' token
        if (analogRead(sensorPin) <> sensorValue) {
        exit status 1
        This report would have more information with
        "Show verbose output during compilation"
        option enabled in File -> Preferences.
        I think it does not like the <>. When I changed it to == it compiled fine.
        void HSSetup() {
        void HSloop() {
          Sorry but I am used to coding in other languages.
          Change:
          to
          if (analogRead(sensorPin) != sensorValue) {
          Greig.
          Scripts =
          Various
            Not a problem, I googled it and I saw it as well.
            Unfortunately now I do not get open or close but random values and then it stops sending them to the plugin. I know the pins are correct because I use them on a different board, I'm I reading it incorrectly? this sensor should be on or off.
              What sensor is connected to the Analog pin?
              Greig.
              Scripts =
              Various
                This one
                ZP4510 Liquid Water Level Sensor Vertical Float Switches
                https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
                  Originally posted by aldo View Post
                  This one
                  Ok I think this is just a switch and not an analog device so you need "digitalRead"
                  Try this
                  void HSSetup() {
                  void HSloop() {
                      // read the input pin and compare to the last state
                      if (digitalRead(sensorPin) != sensorValue) {
                        sensorValue = digitalRead(sensorPin);
                        SendToHS(1, sensorValue);
                  Scripts =
                  Various
                    You are fantastic, thank you.
