Problem with input
  • Problem with input
    I have done a setup with a SR501 PIR on a NodeMCU. It all connects fine, but it doesn't recognize any changes.
    I know that the setup do work, since I have tested it with another sketch outside of HS.
    Anyone have a clue ?
    Are you using the API or normal sketch?
    what pin is it connected to?
    Have you seen THIS
    The more info you give us the easier it will be to find the fault.
    Greig.
    Scripts =
    Various
      I have used the D1 for the input of the sensor and D7 for the output to LED. I use the normal sketch.
      I saw that post with the inputs. I have used the drop down menu in the config to set the pins.
      This is the wiring I have. http://www.instructables.com/id/IoT-...MCU-and-BLYNK/
      I have also tested the sketch, which works
        is it the input, output or both that is not working?
        what is in the log?
        Greig.
        Scripts =
        Various
          It's the input
            There are only some keep alive messages in the log
              Have you tried a different pin?
              Send me a debug log of you triggering the input and output as this might help track it down.
              Greig.
              Scripts =
              Various
                Where di I find the debug log...
                  on the plugin config page there is a tick box to enable the debug log. Then try and trigger the input and output. Then go back und uncheck the debug tick box and this will generate a download link on the page. Click on it to get the file and send it to me.
                  Greig.
                  Scripts =
                  Various
                    It's Attached....
                    If I go the API way, is it possible to Write all the codes myself ?
                      It's Attached....
                      Yes. As a matter of fact, you have to.
                      I'm assuming you are familiar with an arduino sketch format. With the API version, imagine you have an empty setup (HSSetup) and loop (HSLoop) and you have to fill in the appropriate things for what you are wanting to do. That might involve including some libraries depending on what you need.
                      In your loop, you now have two new commands which allow you to read or write to the HS3 devices.
                      Actually pretty straight forward when you get your head around it.
                      Here is my explaination as simple as I can think of.
                      //  Start of API sketch. This is just to illustrate the API sketch structure.
                      // Add any libraries you might need here
                      void HSSetup() {
                        //Add YOUR SETUP HERE;
                      void HSloop() {
                          //Add YOUR CODE HERE;
                          /* To Send Data to Homeseer use SendToHS(Device,Value)
                           Eg.. SendToHS(1,200); where 1 is the API device in homeseer and 200 is the value to send
                           To Recieve data from Homeseer look up the FromHS array that is updated when the device value changes.
                           Eg.. FromHS[5] would be the data from API Output device 5
                           All code that is located just below this block will execute regardless of connection status!
                           You can include SendToHS() calls, however when there isn't an active connection, it will just return and continue.
                           If you only want code to execute when HomeSeer is connected, put it inside the if statement below.
                      void setup() {
                      HSSetup();
                      void loop() {
                      HSLoop();
                      // End of API sketch
                        I have tested a little bit more, it works when I use an Uno Board, but not when I use a NodeMCU. Tried both version 0.9 and version 1.0
                          void HSSetup() {
                          void HSloop() {
                          void setup() {
                          HSSetup();
                          void loop() {
                          HSLoop();
                          I tried the API too, but still no reaction
                            OK looking at your log you have the device set to be an Arduino and not a NodeMCU and I am a little confused as V139 which you are running has no support for the NodeMCU API as this was added in V140.
                            You also have this connection with serial which I also dont understand as this is a wifi based board and is to connect to your network.
                            Greig.
                            Scripts =
                            Various
                              I did have the .139 and tried the NodeMCU (not API), without luck, upgraded to .140 which have the API version to.
                              AFter a little bit of troubling with this to, I manage to get it work.
