Best way to update LCD with NodeMCU?
  • Best way to update LCD with NodeMCU?
    I just got the ESP hardware running with the LCD.
    Right now from a script I update the device string associated with the LCD line, then I tell it to send the screen with that device in the event.
    Is there a direct way from a script to send a string to a particular LCD line I am not seeing?
    Thank you all.
    ~Bill
    Bill,
    Try setting the device value to 100 as this should send the text set in the string to the device. I have not checked the cod but I think this is what I did.
    Greig.
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      Thank you so much. I'll give it a shot tonight.
      ~Bill
        Just did a quick test and you will need to use CAPI and "Send" is the command you need.
        I would add this function to your script:
        Function CallCAPI(ByVal intDevRef As Integer, ByVal strDevCmd As String) As CAPIControlResponse
            CallCAPI = CAPIControlResponse.Indeterminate
            For Each objCAPIControl As CAPIControl In hs.CAPIGetControl(intDevRef)
                If LCase(objCAPIControl.Label) = LCase(strDevCmd) Then
                    CallCAPI = hs.CAPIControlHandler(objCAPIControl)
                    Exit For
                End If
            Next
        End Function
        Then all you need to do is call the function with the required info like this:
        CallCAPI(1275,"Send")
        I hope this helps you.
        Greig.
        Scripts =
        Various
          This is the one that worked - thank you
                      Exit For
                  End If
              Next
          End Function
          Greig.
          ~Bill
            Glad to help. Have fun.
            Sent from my SM-G925F using Tapatalk
            Scripts =
            Various
