Having trouble set API device with script
  • Having trouble set API device with script
    I have a arduino API output created and it turns on and off correctly from the device management screen.
    I can't figure out how to turn it on and off from a script.
    Here is the script (vbs)
    ' this code toggles the devices ArduinoDevice and VirtualDevice each time it is run
    sub main
    ArduinoDevice = "Arduino Devices Arduino Plugin Board:3, API output:0"
    VirtualDevice = "Virtual Virtual dummy"
    ' This does not work using the Arduino device
    dvRef = hs.GetDeviceRefByName(ArduinoDevice) ' this does return a correct device ref
    dvRef2 = hs.GetDeviceRefByName(VirtualDevice)
    if hs.IsOn(dvRef) then
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(dvRef,True,"Of f",False,False)) 'turn device off
    else
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(dvRef,True,"On ",False,False)) 'turn device on
    end if
    ' same code works with the virtual device
    if hs.IsOn(dvRef2) then
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(dvRef2,True,"O ff",False,False)) 'turn device off
    hs.writelog "debug", "Off"
    else
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(dvRef2,True,"O n",False,False)) 'turn device on
    hs.writelog "debug", "On"
    end if
    end sub
    The script runs with no errors. In the log, it shows that an event was run which ran the script. It also says that the virtual virtual dummy device was set. Nothing about the arduino device.
    I think HS.ISON is your problem.
    Try setting the device value pairs for on and off and off then set the control use for them and it should work but I would just check for the on value you are looking for.
    Greig.
    Scripts =
    Various
      Greig.
      The hs.ison was the problem. I approached the problem from another direction and it is now all working.
