Read inputs/write outputs with 1-wire
  • Read inputs/write outputs with 1-wire
    Is there a way to add digital I/O to 1-wire?
    I'm asking because it makes it a lot easier to connect my switches and if possible the corresponding leds (24V ).
    The 1-wire solution saves me a lot of effort with the wiring and the Ethernet V3 would be sufficient.
    An API sketch could be solution but it would be great to keep the "standard" functionality.
    Peter.
    sorry I missed this post.
    You are correct in thinking that the only solution you have for this is to write the code to your own API Sketch.
    Greig.
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
