Read inputs/write outputs with 1-wire
  • Read inputs/write outputs with 1-wire
    Is there a way to add digital I/O to 1-wire?
    I'm asking because it makes it a lot easier to connect my switches and if possible the corresponding leds (24V ).
    The 1-wire solution saves me a lot of effort with the wiring and the Ethernet V3 would be sufficient.
    An API sketch could be solution but it would be great to keep the "standard" functionality.
    Peter.
  • #2
    sorry I missed this post.
    You are correct in thinking that the only solution you have for this is to write the code to your own API Sketch.
    Greig.
    Scripts =
    Various
